A9L2 - FKARCH and FKARC1
Posted: 2026 May 19, 14:34
by olddog
Setting up A9L2 from recent download.
When I changed SARCHG to 347, I noticed the comment said to update FKARCH and FKARC1.
FKARCH had 0.99
FKARC1 had 0.20
The comments had instructions to calculate using manifold volume. My intake is Edelbrock Victor Jr part #29215, which is a single plane carb intake with injector bungs welded at every port. I did searches and found manifold volume was 2.7 to 2.8 liters, but in newer strategies it said to use 3.5 liters because this intake behaves like a larger EFI intake.
Honestly I didn't understand what to feed into the equation in the comment. My engine ran quite well on the factory A9L tune. No stumbling or bogging on tip in. So I opened a stock A9L to see what these value are.
FKARCH - 0.2
FKARC1 - 0.25
I entered these values into my A9L2 bin as a starting point. Should I have left those values untouched? How do you properly tune these values?
Re: A9L2 - FKARCH and FKARC1
Posted: 2026 May 19, 14:49
definitely put them back to the a9l2 values
the transient table is where youll make all transient adjustments
those notes are outdated so disregard
As a side note the manifold volume scalar in the new strategies has absolutely no relation to manifold volume at all. Its a calibrate-able pump shot for tip in but more significantly for tip out duration. Thats just a lil unrelated FYI.
Posted: 2026 May 19, 16:06
by olddog
