Disable transmission.
Posted: 2026 Mar 31, 18:28
by s74p13s
Swapping from e4od to c6 transmission. What values should I use on the scalars to disable transmission for the eec? I know tstrat should be 0. What value does trload need to be set to? Are there any other scalars that need to be modified?
Thanks for the help
Re: Disable transmission.
Posted: 2026 Mar 31, 19:29
0 as well
theres a 6 cyl and an 8 cyl manual file, you can download either and compare as well
youll want to nullify the tot to 100 deg F and dial in dashpot
Posted: 2026 Mar 31, 22:06
by s74p13s
Sounds good, thanks for the info decipha!
