OMAE2 compatible with MPC-204?
Can be used on all 2002-2003 harley trucks and lightnings.
mechanicalmatch
CVAF1
4R70 3.08
On the download page, under OMAE2, you have a note that MPC-204 is not verified. Is this still the case? I have a MPC-204 and thought about trying it out with OMAE2. I started converting the EKO2 file to work for me. I am about half way thru. Do you have a non supercharged file I can reference?
Vehicle is 00 f150 4.6 4r70. I will be going to junkyard next week to get a couple more ECM's and if MPC-204 isn't compatible, do you have a suggestion of something that would be common I could look for so I can try this strat? Been on CVAF1 for 6 yrs. Would like to play with something else.
Re: OMAE2 compatible with MPC-204?
yes still the case
omae2 is for a 4r100 not a 4r70w so its not going to work
why not stick with cvaf1 if you already have one and presumably a working tune after 6 years?
You can go the fbgi0 route with an 03/04 luxury sedan ecu. But those may not support the CHT. Can't hurt to try though.
