ECT and CHT on a 351 C
Posted: 2025 Oct 07, 10:32
Guys, looking for some help on which temperature sensors to use and where they should be located. I have a 351 Cleveland that I am wiring up with an EEC-V for SEFI. I have the original single lead temperature sensor in place but the ECM also needs the CHT (cylinder head temperature). Which sensor would I use and where should I put it? I am using Edelbrock Performer aluminum heads and don't see a spot for a CHT temp probe.
I have a friend with a Cleveland running on the ProM system and his has the original single wire temperature sensor on the water pump and a two wire sensor just behind it on the block. I attempted to copy this format but the only plug I have available is larger than the Crown Vic 2 wire sensor. I have a brass adapter 1/2" NPS to 1/4" NPS but I must be dealing with SAE vs. metric threads because when I went to install the sensor in the brass adapter the threads were all chewed up.
So 2 questions
1. Is this the correct location for the CHT (behind the water pump, on the block)?
2. Does anyone have an adapter that works to go from the 1/2" NPS thread to the CHT sensor thread or a 2 wire sensor that fits 1/4 NPS?
So 2 questions
