TunerPro RT Update - Aug 28, 2025
Posted: 2025 Sep 24, 14:25
New update rolled out last month.
Knowledge is Power!
http://forum.efidynotuning.com/
5.00.10146.00 (General Release) 8/28/25)
Feature: When editing the bin, the corresponding item in the XDF item tree and parameter summary list turns red. Changes are reset when the bin is saved to file.
Feature: Difference tool: double clicking a difference will not only open the editor, but for tables and functions will now also select the cell that corresponds to the difference
Feature: For tables with internally defined axes, you can now select and see the selected state of the column or row header cell. This allows you to copy and paste these values between tables (and to external programs like Excel).
Fix: Function editor: when the function is being graphed, typing in changes in a cell now properly updates the graph
Fix: For compaitilbity with some K-line OBDII interfaces, when the acquisition serial port is opened, the DTR and RTS lines are toggled off and held there for 20ms, then back on again.
Fix: percentage comparison mode is now consistent with difference compare mode
Fix: If a table cell is actively being edited and the 'X' button is pressed to close the editor, the user will be asked if they'd like to apply the change before closing the editor.
Fix: In the Difference Tool, changes in addresses that fell within an axis that is internally defined within a table were not be resolved to the table.
