Page 1 of 3
tgg2 tune help butchered tune fueling and perload problems
Posted: 2025 Sep 21, 22:27
by caprimadness
1998 mustang ecu (tgg2) explorer wiring harness
pro m slot meter in 3 inch tube
78/75 vs racing turbo
deatchwerks 95lb injectors
pump e85 testing at e70
4r70w with lock up fixed line pressure valve body with transbrake
i know this tune is probaly butchered can i get any input on how to fix it or what is going on ill attach the current tune and a wot log showing weird commanded afr up top
Re: tgg2 tune help butchered tune fueling and perload problems
Posted: 2025 Sep 22, 14:51
by caprimadness
Willing to pay for resolution
Posted: 2025 Sep 24, 01:59
by wwhite
Whats redux off?
Has that been programmed with HPTuners?
I cannot open the .xdl file.
Get a stock bin and start over, you have a backup right.
Posted: 2025 Sep 24, 13:37
by caprimadness
the xdl opens up for me i just downloaded it and it works for me you cant program 98 ecus with hp tuners it was done with delta force i attached my adx with the wideband the truck has on it added to it
Posted: 2025 Sep 27, 20:09
thats not a tune thats a garbled and swiss cheesed corrupted excuse of a tune
it looks to be banging the oss limiter but nothing is dialed in and cant be the way thats setup.
Posted: 2025 Sep 28, 00:35
by caprimadness
can you send me a base tune to work off from please and if you need more money then what i have sent already just let me know and ill get it to you
Posted: 2025 Sep 28, 10:13
Here you go give it a try. You'll need to literally dial in everything but you should be able to get the maf situated fairly quickly and then focus on getting the rest situated. Should be leaps and bounds better than what you had before and you should be able to actually dial it in now.
Make sure you read all of the write ups on the homepage at least 3 times.
btw- glowsport uses the same wideband transfer as plx and on3, it already logs correctly automatically
Posted: 2025 Sep 30, 01:09
by caprimadness
i noticed that there is no transmission functions with this xdf right now the truck doesnt have lockup and wont shift into overdrive
Posted: 2025 Sep 30, 05:39
<that has nothing to do with the xdf>
I thought you had a full manual vb so disabled the ecus control of it
post the log and ill take a look and re enable the trans
Posted: 2025 Sep 30, 06:48
by caprimadness
It’s a lentech auto shift valve body with fixed line pressure and a trans brake it works like a factory 4r70w valve body as far as the tune what do you want a log of just driving it ?
