(GTG2) incorrect maf transfer function and injector values
Covers v8 mustangs in 99-early 01 years. Can be configured for V6 easily and cobras as well as trucks and other fords if hardware is compatible.
caprimadness
Supporting Member 2
Vehicle Information: 1990 mustang gt
A9l
302 junk Chinese heads
Gt40 intake
B303 cam
Shorty headers
24lb injectors
80mm maf
5 speed
Unread post by caprimadness »
i have a gtg2 bin that when i load it into tuner pro with decipha's cvaf1 xdf the maf transfer function and injector values are way higher then then should be what am i missing
cvaf1.gtg2.bin
(256 KiB) Downloaded 465 times
Re: (GTG2) incorrect maf transfer function and injector values
That is correct.
You need to put in your actual injector high slope -OR- set the scaling percentage to 1.
