Tip-in fuel
Posted: 2025 Sep 01, 19:42
Working on my tune some more. VE table is dialed in. I'm struggling with transient fuel (tip-in or accelerator pump on a carb). When I goose it, the wideband very momentarily goes offscale lean then just as fast swings rich, down to 11:1 or so before coming back to stoich. As a result, the truck bucks a little bit if you stab it.
I know there's a parameter to adjust that would correct this, but I'm having trouble figuring out which one. Changing FN1303 (accel enrichment) by up to 50% plus or minus doesn't have a noticeable effect. Do I need to try FN1321? Is there another parameter to try?
