X3Z Question
Posted: 2025 Jun 21, 18:17
Decipha, I have a couple of questions if you don't mind:
I have a HCI car that just got a 10# Procharger, 60#LU Ford injectors and a VMP INM-019 mass air in a 3" tube, Holley Systemax intake, TF heads, cam designed by the engine builder but was pretty mild,and LT's. Without a tune at ALL, It starts fine cold, (I did just use a stock X3Z code for kicks and modified the Crank Fuel numbers and now it does fine hot),revs fine and they even drove it a little ways even and said it drove great, so question:
1) Wondering how that is possible?
Also, (and you can chastise me if I did wrong! :) ) But I DID load a tune you sent me recently with the same maf and injectors for an A9L code that had a turbocharger on it but I was
2)Thinking it can interchange with the Z3X strategy? and it ran awful, could barley keep it running,
However, I could not get my NTK/Powerdex wideband to work at all even with trying 2 sensors (one was brand new) and it worked fine a month ago, kept throwing a sensor 4 code. So I got no information on a/f so it might just be extremely lean ( No indication it was rich, I.E. no black/gray smoke, no sooted plugs, etc.)
3) Can you put the maf curve for a HPX-E/VMP INM-019/SCT BA 5000 on the website? I tried to copy and paste the maf curve into a X3Z code without success but obviosly I'm no computer whiz!!!
Just wondering how the thing ran so good stock and like crap when it should have at least been much closer than a stock tune unless the A9L2 base tune you sent for the other car was way different and/or it can't be used on the X3Z
TIA for ALL the help you provide big dummies like me!!!
