2025 F150 Wont Shut Off - Because USB Ports Powered
Posted: 2025 Jun 21, 12:02
Posting this here as a PSA.
In my effort to keep the usb charging ports alive with key off I jumped off the usb charging ports with the navigation fuse in the kick panel.
Apparently the usb charging ports circuit is used to shut the engine off because it would not shut off.
Had to remove the jumpers to get the engine to shut off.
I have verified that if you backfeed the usb charging ports with a battery feed the engine cannot be shut off.
