Problems with quarter horse tuner pro etc
Posted: 2025 Jun 04, 02:36
Current problems I’m having
Car runs fine without the quarter horse plugged
Throws a check engine light for egr being disconnected
But if I plug it in and it’s loaded with the a9l2 tune the check engine light flashes really fast and it does not run well I’ve tried redownloading the tune but still the same thing
I’m also having problems with getting my wideband to show up on the data I’ve tried ever guide I can find still no luck I’ve check the voltage and I have it tapped into the correct wire on the ecu connector still nothing
im really about to give up on the quarter horse and go to my tried and true delta force software the data logging might not be worth all the headache
I’m running the a9l2_240103.bin gufx_240206.xdf and the decipha_230417.adx
