2004 Econoline E-350SD - Tuning, Auto-to-Manual
Posted: 2025 Mar 31, 18:30
Greetings. - I believe I'm posting in the right spot, as I did not see any model-specific subs covering my application.
I'm preparing for an Econoline 4WD conversion, involving auto-to-manual, and I believe I've sorted out all of the physical / mechanical challenges. The subject vehicle is equipped with a 5.4L 2V / 4R100. At this point, I have the hard parts, but I am seeking to educate myself regarding what other considerations should be made. - I am new to tuning, so this is a learning process.
Though, there will no doubt be more, my initial concerns are:
-Am I able to utilize the stock ECU, and if not, what ECU should I be looking for?
-The ZF6 transmission includes no provision for a speed sensor. - What should be done to facilitate the stock speedometer? - I should add that the rear Dana 60 axle is being replaced with a 2005 10.5 Sterling from the donor truck.
Thanks in advance for comments. - Feel free to add any relevant thoughts.
