Gasoline Switch
chaby
Vehicle Information: 1988 F150 4wd XLT Lariat, EEC IV A9P Moates QH, 408w fully forged, 10.5:1, .565-.574 232/240@ .05 112 LSA, AFR185s, EV6 30 lb FRPP @ 55 psi, Eldelbrock dual plane intake, 4.56 gears, AOD.
Gasoline Switch
Unread post by chaby »
What does the fuel switch (gasoline, E10, E85, etc.) actually do in the GUFX statagy?
Re: Gasoline Switch
same as it does for any ecu
its a global fuel modifier based on your actual fuel your burning
very important its as accurate as possible especially when dialing in your fuel
chaby
Re: Gasoline Switch
It effects open loop & closed loop?
Re: Gasoline Switch
yes, its a global fuel modifier
