stock and idle issues
Posted: 2025 Feb 08, 18:06
Hi All,
I tried to look for answers in the thousands of postings on these forums, but must have missed the relevant information.
I have a 1987 Mustang GT, currently completely stock, with the exception of 1.5" short headers, on which I converted the SD to MAF using a 1990 A9L computer. The engine ran fine after the conversion, but I plan to do a HCI upgrade to the engine. So I got a Quarterhorse onto which I installed Decipha's latest A9L2_240103.bin, GUFX_240206.xdf, and DECIPHA_230417.adx using TunerProRT.
The first thing that happened was the (still stock) engine would hunt a lot while cold idling. I figured the new EEC config was trying to learn the engine. But the cold idle hunting never went away after many miles of driving and stops and restarts. I drove the car around for several miles while recording the readings with TPRT, and maybe some day I'll actually understand all the numbers I recorded.
I noticed that just before coming to a stop, with the clutch disengaged, allowing the engine to idle down, it would hunt again, until I come to a complete stop, where it would sort of smooth out. I know the stock computer would idle down as I came to a complete stop. Then while sitting still and idling (with the A9L2 combination), it would be unsteady, shaking the car with some regular periodicity. Also I noticed that the idle would be around 800-850, where as the stock computer idles around 700-750.
During driving at steady state (on the freeway) I would occasionally experience severe stumbling. It would get worse if I try to give it more throttle while it's doing this. I found that this would clear up if I back off the throttle to idle for a few seconds and resume driving.
I think none these symptoms are correct, though the higher idle is tolerable. What would be causing these, and how do I correct them?
I want to get a baseline configuration that works correctly before I start changing values to accommodate my new engine with all the new hardware.
thanks in advance for any assistance you can provide.
