Ford PKCP0A8 OEM BIN needed
Posted: 2025 Feb 07, 10:38
by 034v
GL3A-14C204-TF box
Need for PCM Flash if anyone has it. OEM...
LMK thanks
Re: Ford PKCP0A8 OEM BIN needed
Posted: 2025 Feb 07, 11:36
what year make model engine and trans? Post your read out file so someone can take a look and maybe cross reference and find it if they have it.
Posted: 2025 Feb 08, 13:24
by 034v
I believe 16 F150 eco 6R truck.
Don't have a readout. It was sct flashed and the customer left his door unlocked and tuner in truck.
Posted: 2025 Feb 08, 15:19
by 034v
I can get a readout of the flashed box tomorrow on PCM Flash if that helps. Just need an oem (or corrected revamp of the flash) one so I can load a tune with his replacement tuner he's getting.
Posted: 2025 Feb 08, 19:43
yeah readout would help
why do you need to revamp anything if hes going to be erasing it with a tuner anyway?
Posted: 2025 Feb 09, 09:37
by 034v
decipha wrote: ↑2025 Feb 08, 19:43 yeah readout would help
Can't take a new tune if it's got a current flash. He didn't download the stock file from the device.
At least this is what I've dealt with in the past. Without an OEM flash on the PCM, the (new) x4 or BDX won't load a tune.
Make sense?
Posted: 2025 Feb 09, 10:43
by 034v
I have this one from a 13 3.5 eco/6R 2wd. Similar hardware, different FoMoCo PN. I will get the 16 later today but it will be a tuned readout.
Not sure if this will matter or not. Also attached a mockup XDF for verification reasons.
Details: Bosch MEDG17.0 / DL3A-14C204-ADA / DG170_300_0801 / KGCV5F5 / DSD0 Cal ID
Posted: 2025 Feb 09, 16:13
No that makes zero sense. Who told you it cant take a tune because it has something on it now? Only time it wont be able to recognize it is if someone obfuscated the cal tag. You dont want to use anyone that tunes like that as obviously they have something to hide.
034v wrote: ↑2025 Feb 09, 09:37
Make sense?
Posted: 2025 Feb 09, 16:30
by 034v
Well either way, when I've tried 2 or 4 bank ECU's that were already flashed with a different or same brand device it wouldn't take a flash. It would come up as unable to flash on screen and some BS error. I'm assuming the 4096k ECU's would be the same.
Ill try and post the bin later for the one in question.
