First drive with new engine was rough
Posted: 2024 Oct 10, 18:52
by 1svtfan
Spent the last 2 weeks working thru the tune and getting idle squared away. Been thru all the write ups several times. Thought I had it nailed and went for the first drive today. Lots of bucking and it still dies a lot. (Working on DASPOT Decay still) but thinking everything else looks ok at idle and giving it a bit of RPM in the driveway. Probably looking right at it, but not seeing it. Any thoughts or guidance would be appreciated.
I didn't log it during the short drive, but it richens into the 13's under load. If i need to drive it longer and get a log to set LOAD with EA I can do that next.
I started with the T4M2_210513.bin file
Steve
Re: First drive with new engine was rough
Posted: 2024 Oct 13, 08:53
thats an encrpyted BE file cant open it
You cannot use the t4m2 with BE since some of the values BE shows will not be correct.
if you want to use the t4m2 then its best to use tunerpro
Posted: 2024 Oct 13, 12:14
by 1svtfan
Ok thanks. I've got TunerPro loaded and have been getting used to it in case I couldnt make this work as I know you use it for custom tuning. Was just hoping to fix the issue with BE as I wanted to actually find the problem. Might have done everything correct from the write ups but just have an issue with the BIN.
Does Derek have a strategy for TunerPro? I I've seen you recommend it, but wasn't sure if that was just for BE?
Posted: 2024 Oct 14, 14:08
No, that was just for BE. The tunerpro defs are all free.
I may be wrong but iirc Derek was the originator of all of the original tunerpro defs some near 20 years ago, long before BE as well.
Posted: 2024 Oct 14, 14:29
by 1svtfan
decipha wrote: ↑2024 Oct 14, 14:08 No, that was just for BE. The tunerpro defs are all free.
Thanks!
