NUMEGO Switch
Posted: 2024 Sep 15, 10:00
Using FBGIO_230504 definition, the ENABLE_1_NUMEGO and DISABLE_FOR_2_NUEMGO patches will not apply. "Patch Aborted. Base data does not match." That was anticipated as per the comments. I tried to just manually change all 35 of the NUMEGO switches to 1, but the patches still do not work.
Should the patches be working after manually changing all 35 of the NUMEGO switches to 1, or does the "Patch Aborted. Base data does not match" error suggest something else is wrong?
Do I even need to bother with the patches if the 35 NUMEGO switches are all 1?
