Page 1 of 2
Acquiring Tune From Quarterhorse
Posted: 2024 Sep 09, 19:56
by 2boostedfords
My '90 mustang was dyno tuned years ago by a reputable tuner using a quarterhorse. I would like to acquire the tune from it. Is it as simple as plugging my laptop in to the QH and clicking "Download bin from emulator to Tunerpro"? I'm not sure if the tuner used Tunerpro or BE. Also, does ADX/XDF come in to play here? Thanks
Re: Acquiring Tune From Quarterhorse
Posted: 2024 Sep 10, 09:16
Youll need to read the whole range 256k to find the tune. It wont run once you do til you sort out the bin and rewrite it.
Posted: 2024 Sep 10, 13:49
by 2boostedfords
How do I do that? I’ve read the getting started page but I’m still confused. Thanks.
Posted: 2024 Sep 11, 20:13
use the gufx xdf and read the qh, if the file is garbled load in the fbgi0 xdf and read the qh again
post both those files here.
Posted: 2024 Sep 16, 14:07
by 2boostedfords
So I have a F3V2 chip instead of a QH like i thought. Which is fine. I still want to grab the bin off it, if possible. I'm using my jaybird but I am a little confused by the bank and setting the addresses. Does this look correct?
Posted: 2024 Sep 17, 11:12
if using the jaybird you can read the single bank tune directly
set the range from 32000 to 3ffff as outlined in the getting started write up
the 256k read was for the qh with a BE tune so be sure you grabbed it since no telling what position they wrote it to
Posted: 2024 Sep 17, 12:08
by 2boostedfords
Ok, I thought that may be the case so I pulled that too. Even still, it doesn't seem correct to me? When I load it up a lot of settings read wrong, rev limit set to 41 rpm etc.
Posted: 2024 Sep 17, 14:07
prob going to need to be converted then
most likely a different strategy
ill take a look 1st chance
Posted: 2024 Sep 17, 16:54
by 2boostedfords
Great, thanks Decipha!
Posted: 2024 Oct 17, 16:09
That's an A9P tune file they barely edited. Definitely time to delete it and start over.
Attached
Fill out the vehicle info sheet and PM it to me and I'll post a tune for you that'll be 1000x better guaranteed.
