Page 1 of 3
[READ0] Strategy File
Posted: 2024 Aug 29, 17:18
Attached brief def file I made back in 2021 with datalogging added.
If anyone wants to try it out and post back a log.
Re: [READ0] Strategy File
Posted: 2024 Sep 05, 09:02
by BOOSTEDEVERYTHING
I will see if I can get you a log this weekend. I haven't looked into the DEF file yet, are the areas defined to delete EGR, PATS, and rear Cat monitors? Those are the minimum requirements I need to make the truck run basically.
Posted: 2024 Sep 08, 12:15
Does not poll any data at all. I can load the CRAI8 adx and it will poll data that is not correct of course, but when I load the READ0 ADX file it does not read anything at all. Just figured I would post an update. Does the file need to be named the same as it is posted to work? I renamed it with the strategy name so I can keep the adx files straight.
Posted: 2024 Sep 08, 12:28
nah i need to add the que msg to the config
Posted: 2024 Sep 08, 12:39
nvm, i didn't have a checksum.
Should poll data now. Give her a try. New ADX posted above. Same name as before so overwrite the old one.
Posted: 2024 Sep 08, 12:41
PATS is there but egr and cats aren't. Aren't needed to make it run and doesn't affect anything.
When a premium member needs more I'll add more to it.
Posted: 2024 Sep 09, 07:57
No problem. I will give it a try later today and let you kno0w. Thanks. Hopefully I may have some of it in my DIR file and can add to it. Thanks
Posted: 2024 Sep 13, 20:30
by Snake0503
tired loading up the new ADX file I still could not get it to poll data
Posted: 2024 Sep 14, 09:10
yeah something has to be configured wrong, i'll give it a look over once i get more free time to check it out fully
Posted: 2024 Sep 14, 13:37
by Snake0503
thank you
