1DGA disassembly
Jamie from oz
Re: 1DGA disassembly
Yes they have used a template and just ### out all the things they haven't found .
Won't be too hard to find most of the main things.
No, it's more than that.
Yeah, stand back, I'll wave the wand.
Jamie from oz
Dimitrios now you have sad working and a 1dga_256k_dir we can try to find things .
you had looked in the A9L _lst and seen the code / calibration below
9ada: 0a                  byte      a            DFSVS                             # Fuel Shut Off Deceleration Min MPH - DFSVS
9adb: 04                  byte      4            DFSVSH                            # Fuel Shut Off Deceleration Min MPH Hysterysis - DFSVSH
9adc: 00,00               word      0
9ade: 00,00               word      0
9ae0: 00                  byte      0
9ae1: 00                  byte      0                                              # Fuel Shut Off PT Enable -  1 = PT decel fuel shut off, 0 = CT decel fuel shut off.
9ae2: 55                  byte     55            MinECT_adp                        # Adaptive ECT Min - AFECT1
9ae3: 71                  byte     71            MaxECT_adp
9ae4: 32                  byte     32            Minact_adp                        # Min ACT for Adaptive Control - AFACT1
9ae5: 64                  byte     64            Maxact_adp                        # Max ACT for Adaptive Control - AFACT2
9ae6: 3c,00               word     3c            ADAPTIM                           # Adaptive Delay Time - ADAPTM
9ae8: 7b,04               word    47b
so the same looking code / calibration from 1DGA that you pointed out can be followed to see if its what you think.
9822: 0a                  byte      a
9823: 04                  byte      4
9824: 00,00               word      0
9826: 00,00               word      0
9828: 00                  byte      0
9829: 00                  byte      0
982a: 55                  byte     55
982b: 71                  byte     71
982c: 32                  byte     32
982d: 64                  byte     64
982e: 3c,00               word     3c
9830: 7b,04               word    47b
A9L
4e20: b3,fc,5c,1a         ldb   R1a,[Rfc+5c]     R1a = DFSVS;
4e24: 9b,74,3f,1a         cmpb  R1a,[R74+3f]
4e28: d9,05               jgtu  4e2f             if (R1a <= Mph_FiltH)  {
4e2a: 91,08,ca            orb   Rca,8            Dfsvs_hys_flag = 1;
4e2d: 20,0f               sjmp  4e3e             goto 4e3e; }
4e2f: 7b,fc,5d,1a         sb2b  R1a,[Rfc+5d]     R1a -= DFSVSH;
4e33: d3,09               jnc   4e3e             if (R1a >= 0)  {
4e35: 9b,74,3f,1a         cmpb  R1a,[R74+3f]
4e39: d1,03               jleu  4e3e             if (R1a > Mph_FiltH)  {
4e3b: 71,f7,ca            an2b  Rca,f7           Dfsvs_hys_flag = 0; } }
4e3e: a3,74,de,34         ldw   R34,[R74+de]     R34 = Load;                       # engine load (VE? )
4e42: 8b,fc,5e,34         cmpw  R34,[Rfc+5e]
4e46: db,05               jc    4e4d             if (R34 < [9adc])  {
1DGA
4ed8: b3,fc,60,1a         ldb   R1a,[Rfc+60]     R1a = [9822];
4edc: 9b,74,3b,1a         cmpb  R1a,[R74+3b]
4ee0: d9,05               jgtu  4ee7             if (R1a <= 2bb_MPH_FiltH)  {
4ee2: 91,08,ca            orb   Rca,8            B3_Rca = 1;
4ee5: 20,0f               sjmp  4ef6             goto 4ef6; }
4ee7: 7b,fc,61,1a         sb2b  R1a,[Rfc+61]     R1a -= [9823];
4eeb: d3,09               jnc   4ef6             if (R1a >= 0)  {
4eed: 9b,74,3b,1a         cmpb  R1a,[R74+3b]
4ef1: d1,03               jleu  4ef6             if (R1a > 2bb_MPH_FiltH)  {
4ef3: 71,f7,ca            an2b  Rca,f7           B3_Rca = 0; } }
4ef6: a3,74,da,34         ldw   R34,[R74+da]     R34 = 25a_load;
4efa: 8b,fc,62,34         cmpw  R34,[Rfc+62]
4efe: db,05               jc    4f05             if (R34 < [9824])  {
so we could assume this is same .
1gda dir entry
sym  9822 9822 "9822_DFSVS"         # DT #     (9ada in a9l)
sym  982a 982a "982a_minect_adp"    # (9ae2 in a9l)
the # DT # is that you found that for later reference .
Dimitrios
Vehicle Information: 1992 Ford EB Falcon XR8, EEC IV, custom cam ported and shaved e7, explorer manifold, j3 chip.
Unread post by Dimitrios »
Thanks Mate i’ll check it all out shortly on laptop
Jamie from oz
Dimitrios wrote: 2024 Aug 01, 07:15 Thanks Mate i’ll check it all out shortly on laptop
I think i have a couple errors in the _dir but they will show up in the _msg that sad creates .
easy to fix its just things like i put : infront of a name that should have been "
Jamie from oz wrote: 2024 Jul 29, 18:23 to be put into a text file 1DGA_256k_dir
was using sad v4.12a
jamie.
Consolidated DIR with commands from the quoted post.
I've not added info from your more recent posts.
1DGA_256k_DIR.zip
(24.45 KiB) Downloaded 602 times
Jamie from oz
jsa wrote: 2024 Aug 04, 05:07
jamie.
1DGA_256k_DIR.zip
Will check it out
Thanks John
Jamie from oz
I am adding tables to the consolidated dir
Will keep you updated on progress.
Cool
Jamie from oz
have done some of the Dir tables and functions .
and slowly adding scalers and payloads.
just for reference i have posted the dir.zip
1DGA_256k_dir.7z
(6.83 KiB) Downloaded 531 times
