86 GT SPEED DENSITY
DWG
Vehicle Information: 86 FORD MUSTANG GT, DA1 ECU WITH QUARTERHORSE AND BINARY EDITOR, THE MOTOR IS A 331 WITH 12.5 COMP. WORLD SR. HEADS
AIRGAP INTAKE WITH A 1000 CFM THROTTLE BODY, 30LB INJECTORS , 30LB OF FUEL PRESSURE , .565LIFT,221 DURATION, C4 TRANS , 3800 STALL, 373 GEARS
86 GT SPEED DENSITY
Unread post by DWG »
I need a Strategy for LUXO for binary editor 5.224, and a base tune
Re: 86 GT SPEED DENSITY
give sailorbob a shout for the def file
as for the base tune you'll have to find someone that has something similar to your setup thats willing to share
