Foxbody EEC-V
Posted: 2024 May 12, 14:20
Looking for some guidance as I've found limited info in my searches...
Current setup: Boner Stock 92 Foxbody (A9P), '03 4R70w (microshift)
Plans: EEC-V Swap retaining '03 4R70w trans electronics, and factory 92 ignition (TFI/Dist)(I know it's trash)
I'm aware that the DIS is a better setup, and plan on using it on some future projects, however I'm just trying to get my feet wet with the QH on a stocker setup and play around with the 4R70 and tuning parameters before I dive into something that warrants the DIS.
In my searches I've seen the '96 F150 5.0 ECU suggested, but I'm not clear if it will support the requirements I have for the transmission. (would prefer to retain '03 trans electronics).. Before I go on my search for this ECU, I just want to confirm with some of the more knowledgeable guys that this is possible and that ECU is my only option.
Any suggestions or input is appreciated!
Jim
Jim
