Disabling hego 2
brysonwalsh28
Vehicle Information: 1994 mustang gt, 302, 70mm turbo, on3 intercooler, 4R70W, 3400 stall, jmod, trick flow top end kit, 60lb deka injectors, shorties, 3.73, 75mm TB, 80mm HPX 3" maf, moates quaterhorse, binary editor, cbaza, tm40
Disabling hego 2
Unread post by brysonwalsh28 »
Trying to disable hego 2 for my turbo setup. When I disable the hego 2 per instructions the vehicle will not start.
Re: Disabling hego 2
did you set numego to 1 and all of the output ports for cyl 5 6 7 and 8 the same as bank 0 for 1 2 3 and 4 ?
