Page 71 of 71
Re: EEC V file conversion
Posted: 2026 Sep 08, 13:00
by BOOSTEDEVERYTHING
Awesome, I will give these a shot and see what I can come up with. Thank You Guys!!
So, would it be easier to add to and edit an XDF or start a spreadsheet and import it somehow? Thanks again.
Also for a 4 bank pcm do I just change the bank count to 4 and pcm type to eec_256? any other changes under the config tab? thanks
Posted: 2026 Sep 27, 03:28
by jsa
Spreadsheets are used for BE Definitions. A well layed out DIR can be imported to excel then have formulas applied to generate BE definition data. TP uses XDF which looks like XML plus 'special' characters for data. Taking an existing XDF and changing addresses and other detail is easier than using a spreadsheet and some XSL conversion I think.
Posted: 2026 Oct 22, 13:12
by efloth
Some work needs to be done on some of the trans stuff specifically the downshifts and WOT shift points. Don't use any of the patches or flags as those are for CRAI8. They can be removed if no need to implement them. Let me know if I missed something you need.
