Ultracompare is my goto for compare and merge.
V4.14.2 does the duplicate warning in msg. May as well run it on your other DIR too.
I’ll have to try and sit down this weekend and get them sorted out a bit. Not sure what happened. May have had the usb drive disconnect while saving or something and corrupted the file or something. It may take me a while to compare them and merge them together correctly.
I am to a point where I would like to add some things to the READ0 xdf file but am a bit confused as to exactly what goes where when entering the values. Or making a spreadsheet to import into BE or TunerPro. Does someone have a start to a spreadsheet that I could use to start the process or use as a template? I know it has been a while but work actually got busy and so did life but want to get back on this project.
Jamie from oz
I find a xdf or xlsx that is close to the vehicle configuration and modify that .
Jamie's right.
I could dig up a 4 bank blank xlsx for BE if you wanted to go that way.
last i known BE doesnt allow those
If your doing any development at all tunerpro is definitely easier and far superior as you can edit it in realtime. BE had to reload everytime the xls changed.
Ok, do you have a spreadsheet started at all for the READ0 xdf or did you just enter in a few things into TunerPro? Thanks
Or can TunerPro export a spreadsheet file from an xdf?
Jamie from oz wrote: ↑2026 Aug 26, 17:51 I find a xdf or xlsx that is close to the vehicle configuration and modify that .
Not sure what would be close to an Explorer PCM, maybe an SN95 Mustang?
Jamie from oz
I have a Australian 4 bank xlsx that I can strip a couple things out and post that if you need ( AU 2000 falcon ) and think there might be one posted in the eectuning forum)
There are a number of multibank XDF's on this site that could be used as a baseline to edit into READ0.
There are a couple of BE xlsx definitions on eecanalyzer for two bank bins, that could be used as a starting point for for your 4 Bank READ0.
http://www.eecanalyzer.net/index.php/co ... DPFwfZP1wi
http://www.eecanalyzer.net/index.php/co ... Bn1_pkc-1g,,
