Yes L09777 sets the column quantity.
Yes two functions to get row and column, then do the table lookup.
You could add the function subs to your code sequence.
Sure, post up your analysis.
Have you spotted any code for the row count?
No I have not, but I would assume by the functions it calls it would be 8, but It is 16, So I am very confused about how it all works exactly. Looks like it Checks the table 3 times before outputting a value. But I am lost after adding all of the extra code it takes to actually perform a table lookup. Seems very overcomplicated but I am sure I am making it that way in my head..
Here is the complete Table lookup....I think?
ROUTINE FOR swTb34EPPH
09756: a1,1c,5d,36        ldw   R36,5d1c         TMP2L = uuyFn.0x15d1c;
   uuyFn.0x15d1c:
15d1c: ff,70              func  255, 112
15d1e: 50,60              func   80,  96
15d20: 28,40              func   40,  64
15d22: 00,00              func    0,   0
15d24: 00,10              func    0,  16
15d26: 00,10              func    0,  16
15d28: 00,10              func    0,  16
15d2a: 00,10              func    0,  16
0975a: b3,01,93,f3,38     ldb   R38,[R0+f393]    TMP3L = VS_U4_DELTA;
0975f: 10,09              rombk 9
09761: ef,84,93           call  92ae8            SLU92AE8_UUYFn ();
 SLU92AE8_UUYFn:
92ae8: f2                 pushp                  push(PSW);
     # SJump Loop from L92AF3 until Process Value >= value @ Fn_Addr+2             SLU92AE8_UUYFn
92ae9: 9b,36,02,38        cmpb  R38,[R36+2]
92aed: db,06              jc    92af5            if (TMP3L < [Fn_Addr+2])  {       # Unsigned Operation
92aef: 65,02,00,36        ad2w  R36,2            Fn_Addr += 2;                     # Increment to Next Row
92af3: 27,f4              sjmp  92ae9            goto 92ae9; }
  # JC    from L92AED Process Value >= value @ Fn_Addr+2 and PV is Unsigned     SLU92AE8_UUYFn
92af5: 71,df,a2           an2b  Ra2,df           SIGNDSLP = 0;                     # SIGNDSLP Clear 0
92af8: b2,37,3a           ldb   R3a,[R36++]      TMP4L = [Fn_Addr];                # R3A = X>PV
92afb: b2,37,3c           ldb   R3c,[R36++]      TMP5L = [Fn_Addr];                # R3C = Yx>pv
92afe: 7a,36,3a           sb2b  R3a,[R36]        TMP4L -= [Fn_Addr];               # R3A Xd = X>PV - X<PV
92b01: 7a,37,38           sb2b  R38,[R36++]      TMP3L -= [Fn_Addr];               # R38 PVd = PV - X<PV
92b04: 7a,36,3c           sb2b  R3c,[R36]        TMP5L -= [Fn_Addr];               # R3C Yxd = Yx>pv - Yx<pv
92b07: db,05              jc    92b0e            if (TMP5L < 0)  {                 # Unsigned Operation
        # Unsigned CV Increases by Row
92b09: 91,20,a2           orb   Ra2,20           SIGNDSLP = 1;                     # Yxd Negative
92b0c: 13,3c              negb  R3c              TMP5L = -TMP5L; }                 # Invert Yxd Positive
     # Cont  from L92B0C CV Increased by Row, Negative Yxd Inverted Positive       SLU92AE8_UUYFn
     # JC    from L92B07 Unsigned Control Value Decreases by Row, Yxd Positive     SLU92AE8_UUYFn
92b0e: 7c,38,3c           ml2b  R3c,R38          TMP5L *= TMP3L;                   # R3C = Yxd * PVd
92b11: 9c,3a,3c           divb  R3c,R3a          TMP5L /= TMP4L;                   # R3C CVd  = Yxd * PVd / Xd
92b14: 35,a2,02           jnb   B5,Ra2,92b19     if (SIGNDSLP = 1)  {
92b17: 13,3c              negb  R3c              TMP5L = -TMP5L; }                 # Revert Negative
     # Cont  from L92B17 CVd Control Value Delta Reverted to Negative              SLU92AE8_UUYFn
     # JNB   from L92B14 CVd Control Value Delta Positive SIGNDSLP = 0             SLU92AE8_UUYFn
92b19: 76,36,3c           ad2b  R3c,[R36]        TMP5L += [Fn_Addr];               # R3C CV = CVd + Yx<pv
92b1c: 11,3d              clrb  R3d              TMP5H = 0;                        # CV High Byte Clear 0
92b1e: 71,df,a2           an2b  Ra2,df           SIGNDSLP = 0;                     # Clear 0 SIGNDSLP
92b21: 71,ef,a2           an2b  Ra2,ef           SIGNDY = 0;                       # Clear 0 SIGNDY
92b24: f3                 popp                   PSW = pop();
92b25: f0                 ret                    return;
09764: ac,3c,34           ldzbw R34,R3c          TMP1L = TMP5L;
09767: a1,2c,5d,36        ldw   R36,5d2c         TMP2L = uuyFn.0x15d2c;
   uuyFn.0x15d2c:
15d2c: ff,70              func  255, 112
15d2e: c8,70              func  200, 112
15d30: ac,60              func  172,  96
15d32: 64,00              func  100,   0
15d34: 00,10              func    0,  16
15d36: 00,10              func    0,  16
15d38: 00,10              func    0,  16
15d3a: 00,10              func    0,  16
0976b: b3,e4,fd,38        ldb   R38,[Re4+fd]     TMP3L = VSBART_RT;
0976f: 10,09              rombk 9
09771: ef,74,93           call  92ae8            SLU92AE8_UUYFn ();
 SLU92AE8_UUYFn:
09774: ac,3c,36           ldzbw R36,R3c          TMP2L = TMP5L;
09777: ad,08,38           ldzbw R38,8            TMP3L = 8;        = (Table Width) 8 COLUMNS
0977a: a1,3c,5d,3c        ldw   R3c,5d3c         TMP5L = swTb34EPPH;
   swTb34EPPH:
15d3c: 00,fc,00,02,cd,00,9a,00  table    0, 252,   0,   2, 205,   0, 154,   0
15d44: 00,00,00,00,33,00,00,f6  table    0,   0,   0,   0,  51,   0,   0, 246
15d4c: 00,fc,00,00,00,00,00,00  table    0, 252,   0,   0,   0,   0,   0,   0
15d54: 00,00,00,00,33,00,00,f6  table    0,   0,   0,   0,  51,   0,   0, 246
15d5c: 00,fc,00,00,00,00,00,00  table    0, 252,   0,   0,   0,   0,   0,   0
15d64: 00,00,00,00,00,00,00,f6  table    0,   0,   0,   0,   0,   0,   0, 246
15d6c: 00,fc,00,00,00,00,00,00  table    0, 252,   0,   0,   0,   0,   0,   0
15d74: 00,00,00,00,00,fe,00,f6  table    0,   0,   0,   0,   0, 254,   0, 246
15d7c: 00,fc,00,00,00,00,00,00  table    0, 252,   0,   0,   0,   0,   0,   0
15d84: 00,00,00,00,00,fe,00,f6  table    0,   0,   0,   0,   0, 254,   0, 246
15d8c: 00,fc,00,00,00,00,00,00  table    0, 252,   0,   0,   0,   0,   0,   0
15d94: 00,00,00,00,00,f6,00,f6  table    0,   0,   0,   0,   0, 246,   0, 246
15d9c: 00,fc,00,00,00,00,00,00  table    0, 252,   0,   0,   0,   0,   0,   0
15da4: 00,00,00,00,00,f6,00,f6  table    0,   0,   0,   0,   0, 246,   0, 246
15dac: 00,fc,00,00,00,fe,00,f6  table    0, 252,   0,   0,   0, 254,   0, 246
15db4: 00,f6,00,f6,00,f6,00,f6  table    0, 246,   0, 246,   0, 246,   0, 246
0977e: 10,09              rombk 9
09780: ef,b0,96           call  92e33            SLU92E33_Y16SWTb ();
CONTINUED BELOW
# Word Table Lookup with 4 Cell Interpolate. Signed and Unsigned Word Output.
# Byte size PVC column and PVR row values are multiplied by 16 on entry.
# PVC Process Value Column is Unsigned Byte or Word.
# PVR Process Value Row is Unsigned Byte or Word.
# Tb.CV Control Value is Signed when TblSflg is Set 1
# Input: R34 PVC Column to look up.                              = TMP1L  (VS_U4_DELTA)
# Input: R36 PVR Row to look up.                                 = TMP5L  (VSBART_RT)
# Input: R38 Cq Quantity of Columns in Table (Table Width)       = 8 AS PER LINE 09777 ABOVE
# Input: R3C Tb_Addr Table Address                               = swTb34EPPH  (0x15d3c)
# Output: R3E Tb.CV Control Value (Lookup result Output Value)   = TMP6L
###### Entry Point for PVC & PVR Byte Input / Tb.CV Signed Word Output
     # Call  from L09780                                                           Sub_0954e
   SLU92E33_Y16SWTb:
92e33: f2                 pushp                  push(PSW);
92e34: 91,80,96           orb   R96,80           TblSflg = 1;                      # Signed Table B7 Set 1
92e37: 00                 skip                   goto 92e39;
92e39: 11,35              clrb  R35              TMP1H = 0;                        # yPVC^
92e3b: 09,04,34           shlw  R34,4            TMP1L <<= 4;                      # wPVC * 16
92e3e: 11,37              clrb  R37              TMP2H = 0;                        # yPVR^
92e40: 09,04,36           shlw  R36,4            TMP2L <<= 4;                      # wPVR * 16
92e43: 20,06              sjmp  92e4b            goto 92e4b;
92e4b: 5c,37,38,3e        ml3b  R3e,R38,R37      TMP6L = TMP3L * TMP2H;            # wR3E = Cq * PVR^
92e4f: b0,34,3a           ldb   R3a,R34          TMP4L = TMP1L;                    # yR3A = yPVC
92e52: b0,36,3b           ldb   R3b,R36          TMP4H = TMP2L;                    # yR3B = yPVR
92e55: ac,35,34           ldzbw R34,R35          TMP1L = TMP1H;                    # wR34 = yPVC^
92e58: 64,34,3e           ad2w  R3e,R34          TMP6L += TMP1L;                   # wR3E = (Cq * PVR^) + PVC^
92e5b: 09,01,3e           shlw  R3e,1            TMP6L <<= 1;                      # wR3E = ((Cq * PVR^) + PVC^) * 2
92e5e: 64,3e,3c           ad2w  R3c,R3e          Tb_Addr += TMP6L;                 # Tb_Addr = Tb_Addr + ((Cq * PVR^) + PVC^) * 2
92e61: a2,3d,34           ldw   R34,[R3c++]      TMP1L = [Tb_Addr];                # CV1 (Word Size)
92e64: a2,3c,36           ldw   R36,[R3c]        TMP2L = [Tb_Addr];                # CV2 (Word Size)
92e67: 28,25              scall 92e8e            SLU92E8E_wTb.Interpolate ();      # Pass 1
# Word Table 4 Cell Interpolate. Signed and Unsigned Word Output.
     # SCall from L92E67 Pass 1; Lo Row, Lo & Hi Column values                     SLU92E4A_WUWTb SLU92E8E_wTb.Interpolate:
92e8e: ac,3a,3e           ldzbw R3e,R3a          TMP6L = TMP4L;                    # wR3E = yPVC Pass 1
92e91: 37,96,01           jnb   B7,R96,92e95     if (TblSflg = 1)  {               # Jump FE if Interpolate Unsigned
92e94: fe,4c,36,3e,44     sml3w R44,R3e,R36      TMP9L = TMP6L * TMP2L;            # lR44 = wPVC * wCV2 Pass 1
92e99: 37,96,01           jnb   B7,R96,92e9d     if (TblSflg = 1)  {               # Jump FE if Interpolate Unsigned
92e9c: fe,4c,34,3e,40     sml3w R40,R3e,R34      TMP7L = TMP6L * TMP1L;            # lR40 = wPVC * wCV1 Pass 1
     # JNB   from L92E99 TblSflg = 0                                               SLU92E8E_wTb.Interpolate
92ea1: 68,40,44           sb2w  R44,R40          TMP9L -= TMP7L;                   # wR44 = wR44 - wR40
92ea4: a8,42,46           sbbw  R46,R42          TMP0L -= TMP8L - CY;              # wR44^^ = wR44^^ - wR40^^ - cy
92ea7: c4,36,44           stb   R44,R36          TMP2L = TMP9L;                    # yR36 = y(wR44 - wR40)
92eaa: 0c,08,44           shrdw R44,8            TMP9L >>= 8;                      # lR44 = (lR44 - lR40) / 256
92ead: 44,34,44,3e        ad3w  R3e,R44,R34      Tb.CV = TMP9L + TMP1L;            # Tb.CV = w(l)R44 - CV1 Pass 1
92eb1: 37,96,03           jnb   B7,R96,92eb7     if (TblSflg = 1)  {               # Is Interpolate Signed
92eb4: 3f,3f,05           jb    B7,R3f,92ebc     if (B7_TMP6H = 1) return; }       # Is Tb.CV Negative
     # Cont  from L92EB4 Tb.CV Signed value positive                               SLU92E8E_wTb.Interpolate
     # JNB   from L92EB1 Tb.CV Unsigned value TblSflg = 0                          SLU92E8E_wTb.Interpolate
92eb7: 37,36,02           jnb   B7,R36,92ebc     if (B7_TMP2L = 1)  {              # Is y(wR44 - wR40) < x80
92eba: 07,3e              incw  R3e              Tb.CV++; } }
     # JB    from L92EB4 Tb.CV Signed value negativeB7_TMP6H = 1                   SLU92E8E_wTb.Interpolate
     # JNB   from L92EB7 y(wR44 - wR40) < x80  B7_TMP2L = 0                        SLU92E8E_wTb.Interpolate
92ebc: f0                 ret                    return;
92e69: 09,01,38           shlw  R38,1            TMP3L <<= 1;                      # Cq = Cq * 2 (Word Width)
92e6c: 64,38,3c           ad2w  R3c,R38          Tb_Addr += TMP3L;                 # Tb_Addr = Tb_Addr + Cq
92e6f: a2,3c,36           ldw   R36,[R3c]        TMP2L = [Tb_Addr];                # CV4 (Word Size)
92e72: 05,3c              decw  R3c              Tb_Addr--;                        # Tb_Addr = Tb_Addr - 1
92e74: 05,3c              decw  R3c              Tb_Addr--;                        # Tb_Addr = Tb_Addr - 1
92e76: a2,3c,34           ldw   R34,[R3c]        TMP1L = [Tb_Addr];                # CV3 (Word Size)
92e79: a0,3e,38           ldw   R38,R3e          TMP3L = TMP6L;                    # R38 = wCV1|2
92e7c: 28,10              scall 92e8e            SLU92E8E_wTb.Interpolate ();      # Pass 2
     # SCall from L92E7C Pass 2; Hi Row, Lo & Hi Column values                     SLU92E4A_WUWTb
        # wR3E = yPVC Pass 2
        # lR44 = wPVC * wCV4 Pass 2
     # JNB   from L92E91 TblSflg = 0                                               SLU92E8E_wTb.Interpolate
        # lR40 = wPVC * wCV3 Pass 2
        # Tb.CV = w(l)R44 - CV3 Pass 2
92e7e: a0,3e,36           ldw   R36,R3e          TMP2L = TMP6L;                    # R36 = wCV3|4
92e81: a0,38,34           ldw   R34,R38          TMP1L = TMP3L;                    # R34 = wCV1|2
92e84: b0,3b,3a           ldb   R3a,R3b          TMP4L = TMP4H;                    # R3A = yPVR
92e87: 28,05              scall 92e8e            SLU92E8E_wTb.Interpolate ();      # Pass 3
     # SCall from L92E87 Pass 3; Interpolated Lo Row & Hi Row values               SLU92E4A_WUWTb
        # wR3E = yPVR Pass 3
        # lR44 = wPVR * wCV3|4 Pass 3
        # lR40 = wPVR * wCV1|2 Pass 3
        # Tb.CV = w(l)R44 - CV1|2 Pass 3
92e89: 71,7f,96           an2b  R96,7f           TblSflg = 0;                      # Reset B7 Clear 0
92e8c: f3                 popp                   PSW = pop();
92e8d: f0                 ret                    return;
CONTINUED FROM ABOVE
09783: a0,3e,3c           ldw   R3c,R3e          TMP5L = TMP6L;   = (Lookup result Output Value)
BOOSTEDEVERYTHING wrote: ↑2024 May 31, 10:20 No I have not, but I would assume by the functions it calls it would be 8, but It is 16, So I am very confused about how it all works exactly.
The two functions scale inputs to table dimensions as outputs. So an 8x8 table is a fair call.
Search for 15CDC does not find any hits in the code.
I've seen tables where two different subroutines access the same table but use different row counts, though that is not evident in this case.
Note swTb23EPPH @ 15c9c is similar.
The column scaler is unusual in that output increases above 0 for the last four rows after the input drops to 0.
The function lookup won't look in those lower 4 function rows as the input has hit the minimum input in the row above.
   uuyFn.0x15d1c:
The row scaler is even more unusual in that an input between 100 and 0 increases the column from 0 to 1.
   uuyFn.0x15d2c:
Looking at the functions alone I'd have gone with 8x8 until I found something to the contrary.
Interpolation. Rather than take the value at the intersection of the row and column, the four nearest cells are interpolated.
Looks ok.
EDIT: See bug details in post below.
Should have dawned on me earlier. You have found a bug.
The table name starts with sw, that is signed word.
The lookup sub Y16SW, that is byte input multiplied by 16, signed word output.
You see the problem...
The table is being treated as bytes.
It should be 2 bytes per word.
8 columns requires 16 bytes per row.
So 8 words per row (16bytes) x 8 rows, problem solved.
@TVRfan
V5.08 has this bug also.
So would there be a way for me to correct how it is being treated? Or would that have to be fixed in the actual SAD programming?
Not sure I understand this.
Really needs a programming fix on SAD.
You could bodge it with a structure command.
A value above 100 and a value below 100 lookup the same column location.
A/C << Error - Invalid Command
unded << Error - Invalid Command
icator << Error - Invalid Command
vehicles << Error - Invalid Command
e << Error - Invalid Command
ons << Error - Invalid Command
ing << Error - Invalid Command
l << Error - Invalid Command
exceed << Error - Invalid Command
 to << Error - Invalid Command
dition << Error - Invalid Command
ssion) << Error - Invalid Command
signal << Error - Invalid Command
 commanded << Error - Invalid Command
Is there a limit of how many characters you can put after a # before SAD starts reading the line in the DIR file again?
I got the above when I added some descriptions to some trouble codes in my DIR file. Was thinking maybe some are too long? They are on the same line as the #.
Are those character 256 or 257?
Sorry, I don’t understand your question.
