V4.012 DIR for RZASA consolidated from various sources.
Details in header of DIR file.
No DIR in the RZASA zip you attached.BOOSTEDEVERYTHING wrote: ↑2024 May 06, 08:57
Also, I am posting my updated OMAE2 and RZASA dir files that I have added to
LST alone is not much use for review.
DIR (and CMT if changed) is all that is required. No need for a copy of SAD to be included.
Looking through the LST you posted, your changes look like stuff that is covered by the RZASA XDF.
The consolidated DIR includes all the XDF stuff, so I'd suggest continuing with the consolidates DIR from here on.
Note what you change with a {7}. Give credit to the source of info or reason for changes, such as strategy name and page.
It would be best to comment out existing lines and add another line for changes you prefer.
I note a couple of immediate inline parameters have names added. That may be intentional or accidental. Without the DIR I can't see if a range was replied. You will see in the consolidated DIR I've elected to comment out Bank 0, 8 & 9 SYM's, with so many of them being immediate values, roughly 1000. SAD won't apply the names in the immediate location usually and may misname other identical values as you have noted yourself. Hopefully a future SAD update will resolve this.
I see you have elected not to use the CMT, you are missing all the info against the Timer structure in LST for starters.
Sorry about that. Not sure what happened there. I did recently looses a whole buch of things on the usb drive I have been using so maybe something went fluky with that zip file. I attached another with my updated dir and comparison spreadsheet.No DIR in the RZASA zip you attached
I go back and forth using it and not. When I start getting confused I rerun SAD without it until I find my bearings or vice versa. I love the comments but sometimes when comparing 2 bins it gets a little overwhelming.I see you have elected not to use the CMT, you are missing all the info against the Timer structure in LST for starters.
- RZASAMY_DIR.zip
- RZASA, OMAE2, and Comparison spreadsheet
- (174.16 KiB) Downloaded 545 times
Most of what you added matches up with parameters in Decipha's XDF, so that is good.BOOSTEDEVERYTHING wrote: ↑2024 May 13, 10:42 I attached another with my updated dir and comparison spreadsheet.
I see you have some additional parameters, so I've added those to the consolidated DIR attached below.
Continue on with the consolidated DIR below.
Awesome!! Will do, Thanks. I will let you know if I come across anything else so you can add it in. I noticed it is very complete though so I most likely won't find anything else. LOL. Thanks very much for putting this dir together. Just have to get used to the formatting of it again. Is this a better way to format the dir file for the future or should I continue on with how I have been doing things?
You can add stuff yourself. Just post up the changes or the updated DIR. There is still some stuff to be found and lots of stuff to be identified.
The format is arranged with making it easier to convert from DIR to a definition in mind. That's a moving target.
When you look at definitions from BE and TP, they both follow
Once V5 is more usable changes will be made to suit such as :UW becomes [UW] or [UW flo=x*42] or whatever.
Could well change it all again. Time will tell.
Symbols, tables and function are parameters that go into a definition, the rest of it is stuff to make SAD work that does not go in a definition.
Special function registers are not editable and of little logging value.
RAM is not editable but holds logging targets.
ROM is editable.
The earlier RZASA dir's I've posted have been a bit disorganised as they were basically DMR conversion with stuff thrown in for testing, so better organised now.
Yes you should keep it organised.
ROM is editable.
The one thing I need some clarification on is the math on some of the ones I am finding in OMAE2. I suspect that the code is calling a hex value in an RBase location and adding a hex value to that to it to come up with a value, Is that correct for the below? If that is the casse, how would I go about finding the actual Rbase value stored in Ree? Thanks
OMAE2:
Suspect it compares to RZASA:
OMAE2:
95b43: 11,2f clrb R2f TEMP5H = 0;
95b45: 8f,ee,20,2c divw R2c,[Ree+20] TEMP4L /= [Ree+20];
95b49: d5,05 jnv 95b50 if (OVF = 1) {
95b4b: a0,00,2c ldw R2c,R0 TEMP4L = ZERO;
95b4e: 20,25 sjmp 95b75 goto 95b75; }Code: Select all
Sub_9635b:
9635b: f2 pushp push(PSW);
9635c: b3,fb,93,00,36 ldb R36,[Rfa+93] TMP2L = NUMCYL_0;
96361: 99,04,36 cmpb R36,4
96364: d7,0a jne 96370 if (TMP2L = 4) {
96366: a3,ee,12,2e ldw R2e,[Ree+12] TEMP5L = [Ree+12];
9636a: a3,ee,10,2c ldw R2c,[Ree+10] TEMP4L = [Ree+10];
9636e: 20,26 sjmp 96396 goto 96396; }
96370: 99,06,36 cmpb R36,6
96373: d7,0a jne 9637f if (TMP2L = 6) {
96375: a3,ee,16,2e ldw R2e,[Ree+16] TEMP5L = [Ree+16];
96379: a3,ee,14,2c ldw R2c,[Ree+14] TEMP4L = [Ree+14];
9637d: 20,17 sjmp 96396 goto 96396; }
9637f: 99,08,36 cmpb R36,8
96382: d7,0a jne 9638e if (TMP2L = 8) {
96384: a3,ee,1a,2e ldw R2e,[Ree+1a] TEMP5L = [Ree+1a];
96388: a3,ee,18,2c ldw R2c,[Ree+18] TEMP4L = [Ree+18];
9638c: 20,08 sjmp 96396 goto 96396; }
9638e: a3,ee,1e,2e ldw R2e,[Ree+1e] TEMP5L = [Ree+1e];
96392: a3,ee,1c,2c ldw R2c,[Ree+1c] TEMP4L = [Ree+1c];
96396: 9b,fb,93,00,00 cmpb R0,[Rfa+93]
9639b: df,4a je 963e7 if (NUMCYL_0 != ZERO) {Code: Select all
98c36: 11,2f clrb R2f TEMP5H = 0;
98c38: 8f,ce,50,2c divw R2c,[Rce+50] TEMP4L /= S.0x1AD6E;
98c3c: d5,05 jnv 98c43 if (OVF = 1) {
98c3e: a0,00,2c ldw R2c,R0 TEMP4L = ZERO;
98c41: 20,26 sjmp 98c69 goto 98c69; }Code: Select all
Sub_993aa:
993aa: f2 pushp push(PSW);
993ab: b3,fa,22,36 ldb R36,[Rfa+22] TMP2L = NUMCYL_0;
993af: 99,04,36 cmpb R36,4
993b2: d7,0a jne 993be if (TMP2L = 4) {
993b4: a3,ce,42,2e ldw R2e,[Rce+42] TEMP5L = S.0x1AD60;
993b8: a3,ce,40,2c ldw R2c,[Rce+40] TEMP4L = S.0x1AD5E;
993bc: 20,26 sjmp 993e4 goto 993e4; }
993be: 99,06,36 cmpb R36,6
993c1: d7,0a jne 993cd if (TMP2L = 6) {
993c3: a3,ce,46,2e ldw R2e,[Rce+46] TEMP5L = S.0x1AD64;
993c7: a3,ce,44,2c ldw R2c,[Rce+44] TEMP4L = S.0x1AD62;
993cb: 20,17 sjmp 993e4 goto 993e4; }
993cd: 99,08,36 cmpb R36,8
993d0: d7,0a jne 993dc if (TMP2L = 8) {
993d2: a3,ce,4a,2e ldw R2e,[Rce+4a] TEMP5L = S.0x1AD68;
993d6: a3,ce,48,2c ldw R2c,[Rce+48] TEMP4L = S.0x1AD66;
993da: 20,08 sjmp 993e4 goto 993e4; }
993dc: a3,ce,4e,2e ldw R2e,[Rce+4e] TEMP5L = S.0x1AD6C;
993e0: a3,ce,4c,2c ldw R2c,[Rce+4c] TEMP4L = S.0x1AD6A;
993e4: 9b,fa,22,00 cmpb R0,[Rfa+22]
993e8: df,45 je 9942f if (NUMCYL_0 != ZERO) {-
Locate where the base value is set for REE, then set an Rbase accordingly.
Hint, search LST for REE.
I did search for REE in LST file and found this in the CALINIT subroutine at L_823E2 and when you follow up to L_823DA you find B302, but I wasn't sure if that was correct or not?
CalInit:
82375: 11,1b clrb R1b CAM_SLOTS_AVBL = 0;
82377: a1,80,02,d2 ldw Rd2,280 TSLAMU1 = 280;
8237b: a1,80,03,d4 ldw Rd4,380 CANP_FF = 380;
8237f: a1,80,05,d6 ldw Rd6,580 Rd6 = 580;
82383: a1,80,08,d8 ldw Rd8,880 ECT_ACT_DIFF = 880;
82387: a1,80,09,da ldw Rda,980 Rda = 980;
8238b: a1,80,0a,dc ldw Rdc,a80 Rdc = a80;
8238f: a1,80,10,de ldw Rde,1080 Rde = 1080;
82393: a1,80,11,e0 ldw Re0,1180 Re0 = 1180;
82397: a1,80,12,e2 ldw Re2,1280 TRIP_MON_LST = 1280;
8239b: a1,80,13,e4 ldw Re4,1380 SCP_COOL_OLD = 1380;
8239f: a1,80,14,e6 ldw Re6,1480 ODU_KEY = 1480;
823a3: a1,80,15,e8 ldw Re8,1580 Re8 = 1580;
823a7: a1,80,16,ea ldw Rea,1680 ENG_ROT_TMR_? = 1680;
823ab: a1,80,17,ec ldw Rec,1780 Rec = 1780;
823af: a1,02,b3,46 ldw R46,b302 TMP0L = SBTR_18MHZ_default;
823b3: b3,f4,07,36 ldb R36,[Rf4+7] TMP2L = [125a5];
823b7: b3,f4,06,34 ldb R34,[Rf4+6] TMP1L = AICE_?x8;
823bb: 99,02,34 cmpb R34,2
823be: df,22 je 823e2 if (TMP1L != 2) {
823c0: a1,86,b3,46 ldw R46,b386 TMP0L = SBTR_21MHZ;
823c4: b3,f4,08,36 ldb R36,[Rf4+8] TMP2L = [125a6];
823c8: 99,04,34 cmpb R34,4
823cb: df,15 je 823e2 if (TMP1L != 4) {
823cd: a1,0a,b4,46 ldw R46,b40a TMP0L = SBTR_24MHZ;
823d1: b3,f4,09,36 ldb R36,[Rf4+9] TMP2L = [125a7];
823d5: 99,06,34 cmpb R34,6
823d8: df,08 je 823e2 if (TMP1L != 6) {
823da: a1,02,b3,46 ldw R46,b302 TMP0L = SBTR_18MHZ_default;
823de: b3,f4,07,36 ldb R36,[Rf4+7] TMP2L = [125a5]; } } }
823e2: c0,ee,46 stw R46,Ree Ree = TMP0L;
823e5: c7,d2,4b,36 stb R36,[Rd2+4b] SPI_BIT_TRANSFER_RATE = TMP2L;
823e9: b1,c1,46 ldb R46,c1 TMP0L = c1;
823ec: 9b,f9,a8,00,00 cmpb R0,[Rf8+a8]
823f1: df,03 je 823f6 if (knk_sensors != ZERO) {
823f3: 91,02,46 orb R46,2 B1_TMP0L = 1; }
823f6: b0,46,0c ldb Rc,R46 HSI_MASK = TMP0L;
823f9: b0,00,1a ldb R1a,R0 HSI_EDGE_MODE = ZERO;
823fc: b1,04,72 ldb R72,4 R72 = 4;
823ff: 34,c4,03 jnb B4,Rc4,82405 if (SCP_UP = 1) {
82402: 91,02,72 orb R72,2 B1_R72 = 1; }
82405: f2 pushp push(PSW);
82406: fa di interrupts OFF;
82407: c4,08,72 stb R72,R8 IO_INT_MASK = R72;
8240a: a1,ff,03,12 ldw R12,3ff HSO_INT_1_MASK = 3ff;
8240e: a1,40,80,16 ldw R16,8040 HSO_INT_2_MASK = 8040;
82412: f3 popp PSW = pop();
82413: 71,ef,54 an2b R54,ef RAMINIT_Flg = 0;
82416: f0 ret return;-
Also wanted to ask if it would be beneficial to copy over the commented out part of the DIR file to my DIR file? Example below..
I found the FIECT_3_SH, Would it benefit me in the future to have the next line from the same address copied over and left commented out? Also, what does the {2} and {3} and {1} stand for after the entries?
SYM 17800 "FIECT_3_SH" #[SY=flo(X/0.5)] #deg F #IOET ECT Min {2}
#SYM17800 "S.0x17800" #[SY=flo(X*1)] # # {3}
