03/04 Mach 1
Re: 03/04 Mach 1
absolutely not
Re: 03/04 Mach 1
Unread post by bad86capri »
ok im a little confused. based off your mbt table for 4 valves adding 11 degrees to the whole table would achieve those numbers. I do understand that the timing table will have to dialed in based on each individual engine needs but im asking if it will close enough to get started. Also is FN2200 the primary timing table or is another table i should be looking at? Again this all for starting out not final.
Re: 03/04 Mach 1
finally attempted my first and it is pig rich and will barely stay running with my foot buried on the gas pedal. not sure what i did wrong or if the tune im using is just that far off.
Re: 03/04 Mach 1
the factory tune is what was read from the ecu and the startup tune is the 03/04 cobra tune
03Mach_Startup_Tune.bin
(256 KiB) Downloaded 501 times
Factory_03_Mach1.bin
(256 KiB) Downloaded 548 times
Re: 03/04 Mach 1
Another issue is the dashboard in the software is not reading out
Re: 03/04 Mach 1
found my issue! the injector offset got corrupted somehow.
Re: 03/04 Mach 1
Snow that im up and running. The ECT is reading -214 on the dashboard but normal on the actual gauge in the car. and im dealing with a hanging idle issue. Any ideas on why the dashboard would reading that far off? ill post a short idle log.
Re: 03/04 Mach 1
Heres the log.
Riffs Mach Idle Log.xdl
(19.32 KiB) Downloaded 528 times
Re: 03/04 Mach 1
After troubleshooting and just being patient i figured most of these issues out. The datalog issue was the patch was not enabled, i thought i enabled the patch when i was putting the base tune together. The hanging idle issue was a bad, brand new iac. This thing was bad right out of the box! Luckily i have a couple of explorers IACs from my foxbody stuff and one of them worked. It still needs dialed as the rpm comes down kinda slow between shifts. Now that i have the IAC working im going to load the QH back in and start tuning. Hopefully i wont have any more mechanical issues, we'll see.
Neald
Vehicle Information: 1989 Ford Bronco II
Stock 2.9 V6, A4ld trans.
CBAZA(6CYL Config)
Moates quarterhorse
Re: 03/04 Mach 1
Unread post by Neald »
Nice work. Just stay patient. And go back to the "getting started " and go in order methodically. Remember to get that fuel dialed in first like the write ups state.
