Page 4 of 4
Re: Looking for tuning help on 1996 Bronco
Posted: 2022 Feb 26, 11:50
your already upgraded
when your info comes through youll get your own thread over there
Posted: 2022 Mar 07, 11:50
by OldBroncoRacer
TexasA&M wrote: ↑2022 Feb 11, 18:15 ok, I'll look into pulling the ECM out and taking a look. Any way to see the label without removing? I'm actually planning to do some interior work this weekend (wiring in new lights), so could pull the kick panel and have a look.
If you haven't figured it out yet, it's behind the E-brake, and access to it is from the engine compartment, so the easiest is to remove the drivers front tire, then the inner liner, get a mirror, and read the label. Kind of a pain. Maybe just go to Autozone, Oreillys, or someone with a code reader - it might tell you.
-ed
Posted: 2022 Mar 07, 14:53
by TexasA&M
I pulled it out last week and read it. Wasn't terribly difficult, but I wouldn't want to do it regularly. Good call on using a code reader... the SCT I'm using to tune/datalog tells me the strategy. I think I would have had to still pull the computer to verify the hardware code though.
Posted: 2022 Mar 07, 20:07
Yeah always best to yank the ecu to see the actual hardware code as its not too uncommon for ecu's to get strategy swapped.
