2006 Mustang & 1993 MarkVIII engine and transmission
Apex
1996 Ford Mustang
2007 Ford F-150 5.4 3v
Re: 2006 Mustang & 1993 MarkVIII engine and transmission
Unread post by Apex »
I would start by going through the circuit and figure out what you're missing, do you have power at relay pin 30 at all times and power at relay pin 85 (in park/neutral and key in crank position)? Does the relay coil energize when you turn the key (power at pin 85) and power at 87 if so? Is your engine block grounded well to the chassis? Etc. etc.
how did you wire up the mlps?
thats pin 2 on your old ecu harness
if need be just rewire the starter trigger wire to the ignition switch
Pguercio1
Vehicle Information: 2006 Ford Mustang with
4.6l DOHC from 93 Mark VIII
Unread post by Pguercio1 »
Ok Michael
I’ll go through it all again
I’ll let you know
Thanks for your help!!!
I really do appreciate it!
Pguercio1
Hi Micheal
I got this all working
Except for the gauge cluster
The only gauge that works is the Fuel
I tried to send you a video,
but it won’t let me upload it.
