I think there is a write up on reading the bin from your PCM using TP and a blank XDF.
Yes you could create a partial def to read your PCM.
I tried it that way, I just can not get it to read well like that. I got the read I have with my old burn 1 and adapters using the old Moates software. Would be nice to get a clean read with tunerpro so I have a good file to start with. The software it is tuned with now is horrible. The old SNIPER/DELTAFORCE stuff. Half of the things I try to change do not seem to affect it, that's why I am trying to learn the disassembly end of it. I would like a better understanding and also be able to build my own def files and hopefully even change or add code to the bin in the future. Like fan control or something like that. I am trying to build a pwm fan controller with an arduino but am failing really well with that right now. LOL
You should be able to get a clean read, using a blank or the old moates software.
By all means have a go with your own definition, but it may equally fail to read until the reasons for previous failures are understood.
Keep in mind that both software and hardware will have to be in place for fan control. Once editing the bin for fan control, the EEC will need to have spare points available and the components in place. You may need to add components.
Is there a component ID write up or documentation that may tell me what to look for as far as EEC Hardware identification goes? I have the hardware manual, but is there a way for someone new at this to id the actual hardware components? I have looked into it a bunch with googles help but have failed to find much.
I did get the good read with the moates software. Was just hoping to be able to read it with BE or Tunerpro, just to make it a bit easier to have a base to edit in the software I want to use. Maybe I downloaded the wrong Blank Def files. Do you happen to have one that will work with tunerpro or BE? Thanks
This is a blank BE def for reading.
4bank.xls
(75 KiB) Downloaded 595 times
Thank You. I will give it a shot. I will need to have a def file to be able to datalog anything at all, is that correct? Is there a base OBD2 type datalogging def I can use Just to verify the basic stuff is operating correctly. I am putting a new PCM in the truck. The one I had in it is a reman and is acting up at times and nt wanting to start. But I do not have any more credits on my old Sniper tuning software to be able to put the tuned file on this new pcm. I am hoping I can read the tuned file out with my moates stuff and put in on a quaterhorse and install that until I can get a def file built to be able to tune and datalog the rest of it.
For BE, a def file with logging patch code is needed for the QH. That has nothing to do with OBD2 logging.
For TP, an ADX file is needed for logging with the QH.
I have no experience with OBD2 logging, but that requires a Mongoose or similar.
Yes you can read your bin and run it on the QH in a replacement ECU.
Jamie from oz
Not sure if you have a generic obd2 adapter that you can use with forscan.
I can data log some of the later eec-v in Australian au falcons with forscan and a elm327 or tactrix open port 2 or vgate fs.
This is only for datalogging generic obd2 not tuning the ecu and not with the QH.
Yes. I have access to IDS so I will just use that. Wasn’t sure if there was a generic adx that had the basic stuff in it already that I could just use with the quarterhorse to make things a bit easier. I’ll just use ids and make it work. lol.
I am having an issue with EQE3. In my message file I have this...
sym 0eeb6 "Sub_0eeb6" # auto
sym 0ef0d "Sub_0ef0d" # auto
sym 0ef41 "Sub_0ef41" # auto
sym 0ef51 "Sub_0ef51" # auto
And in my LST file I have this......
   Sub_0ef0d:
0ef0d: f2                 pushp                  push(PSW);
0ef0e: 10,08              rombk 8
0ef10: ef,86,8f           call  87e99            Sub_87e99_ROM_BANK_CNTRL? (
0ef13: 07                       #arg 1              7 );
0ef14: 12,30              cplb  R30              TEMP6L = ~TEMP6L;
0ef16: 52,2e,30,46        an3b  R46,R30,[R2e]    TMP0L = TEMP6L & [TEMP5L];
0ef1a: 12,30              cplb  R30              TEMP6L = ~TEMP6L;
0ef1c: 88,2c,2a           cmpw  R2a,R2c
0ef1f: db,2b              jc    0ef4c            if (TEMP3L < TEMP4L)  {
0ef21: a2,2b,3e           ldw   R3e,[R2a++]      TMP6L = [TEMP3L];
0ef24: 51,0f,3e,40        an3b  R40,R3e,f        TMP7L = TMP6L & f;
0ef28: 71,f0,3e           an2b  R3e,f0           TMP6L &= f0;
0ef2b: 3e,3e,16           jb    B6,R3e,0ef44     if (B6_TMP6L = 0)  {
0ef2e: 99,01,40           cmpb  R40,1
0ef31: d3,11              jnc   0ef44            if (TMP7L >= 1)  {
0ef33: 99,05,40           cmpb  R40,5
0ef36: d9,0c              jgtu  0ef44            if (TMP7L <= 5)  {
0ef38: 17,40              incb  R40              TMP7L++;
0ef3a: 91,40,3e           orb   R3e,40           B6_TMP6L = 1;
0ef3d: 90,40,3e           orb   R3e,R40          TMP6L |= TMP7L;
0ef40: c3,2a,fe,3e        stw   R3e,[R2a+fe]     [TEMP3L-2] = TMP6L; } } }
0ef44: 34,3e,03           jnb   B4,R3e,0ef4a     if (B4_TMP6L = 1)  {
0ef47: 90,30,46           orb   R46,R30          TMP0L |= TEMP6L; }
0ef4a: 27,d0              sjmp  0ef1c            goto 0ef1c; }
0ef4c: c6,2e,46           stb   R46,[R2e]        [TEMP5L] = TMP0L;
0ef4f: f3                 popp                   PSW = pop();
0ef50: f0                 ret                    return;
Should Sub_0ef41 be a Subroutine on its own, or is that a mistake in the msg file? Or do I need to add something to the dir file to make SAD scan that individual address? This is SAD 4.012. Thanks
