BOOSTEDEVERYTHING wrote: 2023 Dec 29, 14:29 V 4.012
It has naming bugs.
As far as Bgtmr goes, if I only see it in one place do I use the same beginning and end address?
EQE3
DIR
SYM  1070 "BG_TMR"                        #UW # Background loop time
LST
086d7: c3,e2,f0,3c        stw   R3c,[Re2+f0]     BG_TMR = TMP5L;                   # [1070]
I will try and post an example of where i see it and the comparison I found in RZASA that I am going off of.
In EQE3
08743: 44,3c,00,2c        ad3w  R2c,R0,R3c       TEMP4L = R3c;
Of course now that I am looking at it again, maybe I am defining it incorrectly?
DIR
SYM R3C 08743 08746 ".bg_tmr."
I try to make it obvious when I'm naming temp register over a range, that are copies of the real thing.
Never tried making the start and end address the same for a sym range. Try it and report back.
At the moment SAD decodes one type of timer update structure.
At the moment, effort is going into doing that for all timer update structures.
Here's some stuff you can edit into your EQE3 files.
CMT
086C8 # [120E]
086CD # [1210]
086D4 # [1780E] 0x7A12
086D7 # [1070]
086E9 # [120E]
086ED # [1210]
086F1 # [1212]
086FB # [1212]
08701 # [1213]
0870E # [1213]
08714 # [172A]
08719 # [1729]
82406 # [1258F] 0x8
8240A # [1258E] 0x6
8240E # 0x6 != 0x2
82417 # [12590] 0x8
8241B # 0x6 != 0x4
82424 # [12591] 0x8
82428 # 0x6 = 0x6
82431 # [1258F] 0x8
82434 \n\n     # Cont              [1258E] != 0x2, 0x4, 0x6 \t83\s823C8
82434   \n     # JE    from L82411 [1258E] != 0x2, No Jump \t83\s823C8
82434   \n     # JE    from L8241E [1258E] != 0x4, No Jump \t83\s823C8
82434   \n     # JE    from L8242B [1258E] = 0x6, \s46 = 0x780E \s36 = 0x8 \t83\s823C8
82435 # RBA D0 1780E
82438 # [276] = 0x8
8243F # 0x0 != 0x0
82443 # [13EF8]
DIR
RBA D0 1780E
SYM    D0 "CKINDEX"                       #UW # Rbase D0 1780E, L82435
SYM 1258E "AICE_?x6"
SYM 17544 "Tmr_Cmd_Str"                    #   # Timer Command Structure
SYM 1780E "CKINDEX_Str"
Awesome. Thank you very much. I will edit/add those entries and keep plugging away.
Edit: While editing the dir file I remembered a question that I had and maybe you already answered it with your entries to add. Can and address be both an Rbase and a Labeled item with labeled Bytes? Also, you previously defined SYM 1258E "AICE_?x8", should i replace it with the AICE_?x6 instead? also you had SYM 17554 #UY # Timer Command Structure, Do I replace that as well? Looks like there can only be one timer command structure, correct?
BOOSTEDEVERYTHING wrote: 2024 Jan 02, 07:21 Edit: While editing the dir file I remembered a question that I had and maybe you already answered it with your entries to add.
Looks like it.
Yes
Yes
Yes
Seems so.
DIR and CMT updated for the Timer Structure.
RZASA Timers.zip
(193.14 KiB) Downloaded 519 times
I have a question about this....
#                 D
#                 e   F
#       S E   B I c   r
#       e i   i n r   e
#       c g   d v e   e
#       o h m i e m W
#       n t S r r e o R
#       d h e e s n r u
#       s s c c e t d n
What does it mean? Sorry if it is a stupid question.
Yes
I have been second and third guessing myself on a few sym entries because I thought an address could only be one thing. So this is good to know. Thank You! Guess I should have asked that a long time ago instead of assuming.
Look at R40 in the DIR or the description in CMT or LST for the subroutine.
I have a quick question, hopefully...
   Sub_0230e:
0230e: a1,00,0c,48        ldw   R48,c00          FGTMP0L = DRC_DTI0_CON;
02312: 3b,c1,08           jb    B3,Rc1,0231d     if (DARC_INIT_FLG = 0) {
02315: b3,49,8a,00,4a     ldb   R4a,[R48+8a]     FGTMP1L = [FGTMP0L+8a]
How would I find the address for FGTMP0L + 8a ? FGTMPOL is DRC_DT10_CON, which is c00, so, what is the + 8a. If I add them it should be c8a, is that correct? So the FGTMP0L + 8a = c8a, so I would be looking at FGTMP1l = Rc8a....Is that correct?
Sorry if that is not worded really great. I want to make sure I am doing that correctly. Thank You.
C8A but not a register.
You could command an Rbase over the local range and then C8A symbol name could be printed.
Looking at my dir file, do you think I may have enough to create a partial def file to be able to read the file from my pcm with tunerpro rt?
