So...my answer to the above question kind of smacked me in the face today. LOL. I felt completely stupid when I finally saw it. So here is one example of my stupidity......LOL
In EQE3 I have this:
   Sub_8991c:
8991c: a1,17,03,46        ldw   R46,317          TMP0L = 317;
89920: b1,03,34           ldb   R34,3            TMP1L = 3;
89923: b3,ea,51,ca        ldb   Rca,[Rea+51]     FLAGTEMP_BG = [114d1];
89927: 91,08,ca           orb   Rca,8            B3_FLAGTEMP_BG = 1;
8992a: c7,ea,51,ca        stb   Rca,[Rea+51]     [114d1] = FLAGTEMP_BG;
8992e: b2,47,36           ldb   R36,[R46++]      TMP2L = [TMP0L];
In RZASA, I have this:
   Sub_82766:
82766: a1,55,14,46        ldw   R46,1455         TMP0L = P0781FIL;
8276a: b1,03,34           ldb   R34,3            TMP1L = 3;
8276d: fd                 regbk 3
8276e: 91,10,b6           orb   R3b6,10          ISIG_SS_ENA = 1;
82771: f4                 regbk 0
82772: b2,47,36           ldb   R36,[R46++]      TMP2L = [TMP0L];
I was trying to define B3_FLAGTEMP_BG as the ISIG_SS_ENA because it lined up in the code as what B3_FLAGTEMP_BG was in that line of code. I completely ignored that EQE3 was loading the value at address 114d1 into that slot and I should have been defining 114d1 as ISIG_SS_ENA. Then in another subroutine it used the same temp register for something else and I was chasing my tail and changing what I was defining it as. So now I get what I was doing wrong. That being said, Is there a way that I can have SAD work out that B?_FLAGTEMP_BG is what is in that specific byte slot in that specific subroutine so it prints it out in the lst file correctly? And would I have to do a separate entry for every subroutine to make that work correctly? Or is that just pointless to do in the long run anyways?
Also, SAD seems to have missed labeling this particular instance of 317 as P0781FIL. It is defined correctly elsewhere in the lst file. Just got missed here.
Glad you found the error of your ways.
Yes you can specify an address range where a SYM will be applied.
Do something like this as an example.
SYM  003C 033DC 03417 "Tb_Addr"
SYM  003C 82345 86789 "WIP"    :B0
SYM  003C 92345 96789 "WEL"    :B0
SYM  003C "TMP5L"
Individual entries for each range are required, that could be one sub, many subs or part of a sub.
It can be very helpful in some cases, while others are not worth the bother. It's user choice, thankfully SAD has that as a guiding principle.
317; which version of SAD?
It is an immediate load, so a catch 22 as previously discussed.
Version 4.0.12. I have not tried the older versions yet. I did try 4.0.12 on the RZASA bin and got a ton of errors using the dir file you gave me so I went back to using 4.0.7.16b on rzasa.
So SAD really doesn't know what the code is doing as a whole, It just knows what it is doing on that particular line? Is that correct? Is there a way to test the code with the definitions that we have defined in the dir file? I guess I am asking if there is something that will run the sub using the dir entries and give and actual output?
Post up the errors.
As a whole, no, it is not an emulator.
SAD emulates some blocks of code but not all code. It knows lines of code as the starting point.
You could write a spreadsheet to emulate a subroutine. You could write a test bin for a subroutine and run it on an EEC box.
There arn't any good emulators available, that I'm aware of.
It is posted above in my post about my stupidity. Lol. 317 shows as 317 instead of p0781fil. Elsewhere in the lst file it shows up fine. Or do you mean the errors from running the newer version of sad on rzasa?
SAD on RZASA
AH! There are a few....
WOR  2002 2003 << Error - Invalid bank
SYM  2060  << Error - Invalid bank
SYM  2444  << Error - Invalid bank
SYM  26E6  << Error - Invalid bank
SYM  3896  << Error - Invalid bank
SYM  44AA  << Error - Invalid bank
SYM  536C  << Error - Invalid bank
SYM  593A  << Error - Invalid bank
SYM  75CE  << Error - Invalid bank
SYM  8D5C  << Error - Invalid bank
SYM  8D5E  << Error - Invalid bank
SYM  8D60  << Error - Invalid bank
SYM  8D62  << Error - Invalid bank
SYM  8D64  << Error - Invalid bank
SYM  8D66  << Error - Invalid bank
SYM  8D68  << Error - Invalid bank
SYM  8D6A  << Error - Invalid bank
SYM  8D6C  << Error - Invalid bank
SYM  8D6E  << Error - Invalid bank
SYM  8D70  << Error - Invalid bank
SYM  8D72  << Error - Invalid bank
SYM  8D74  << Error - Invalid bank
SYM  8D76  << Error - Invalid bank
SYM  8D78  << Error - Invalid bank
SYM  8D7A  << Error - Invalid bank
SYM  8D7C  << Error - Invalid bank
SYM  8D7E  << Error - Invalid bank
SYM  8D80  << Error - Invalid bank
SYM  8D82  << Error - Invalid bank
SYM  8D84  << Error - Invalid bank
SYM  8D86  << Error - Invalid bank
SYM  8D88  << Error - Invalid bank
SYM  8D8A  << Error - Invalid bank
SYM  8D8C  << Error - Invalid bank
SYM  8D8E  << Error - Invalid bank
SYM  8D90  << Error - Invalid bank
SYM  8D92  << Error - Invalid bank
SYM  8D94  << Error - Invalid bank
SYM  8D96  << Error - Invalid bank
SYM  8D98  << Error - Invalid bank
SYM  8D9A  << Error - Invalid bank
SYM  8D9C  << Error - Invalid bank
SYM  8D9E  << Error - Invalid bank
SYM  8DA0  << Error - Invalid bank
SYM  8DA2  << Error - Invalid bank
SYM  8DA4  << Error - Invalid bank
SYM  8DA6  << Error - Invalid bank
SYM  8DA8  << Error - Invalid bank
SYM  8DAA  << Error - Invalid bank
SYM  8DAC  << Error - Invalid bank
SYM  8DAE  << Error - Invalid bank
SYM  8DB0  << Error - Invalid bank
SYM  8DB2  << Error - Invalid bank
SYM  8DB4  << Error - Invalid bank
SYM  8DB6  << Error - Invalid bank
SYM  8DB8  << Error - Invalid bank
SYM  8DBA  << Error - Invalid bank
SYM  8DBC  << Error - Invalid bank
SYM  8DBE  << Error - Invalid bank
SYM  8DC0  << Error - Invalid bank
SYM  8DC2  << Error - Invalid bank
SYM  8DC4  << Error - Invalid bank
SYM  8DC6  << Error - Invalid bank
SYM  8DC8  << Error - Invalid bank
SYM  8DCA  << Error - Invalid bank
SYM  8DCC  << Error - Invalid bank
SYM  8DCE  << Error - Invalid bank
SYM  8DD0  << Error - Invalid bank
SYM  8DD2  << Error - Invalid bank
SYM  8DD4  << Error - Invalid bank
SYM  8DD6  << Error - Invalid bank
SYM  8DD8  << Error - Invalid bank
SYM  8DDA  << Error - Invalid bank
SYM  8DDC  << Error - Invalid bank
SYM  8DDE  << Error - Invalid bank
SYM  8DE0  << Error - Invalid bank
SYM  8DE2  << Error - Invalid bank
SYM  8DE4  << Error - Invalid bank
SYM  8DE6  << Error - Invalid bank
SYM  8DE8  << Error - Invalid bank
SYM  8DEA  << Error - Invalid bank
SYM  8DEC  << Error - Invalid bank
SYM  8DEE  << Error - Invalid bank
SYM  8DF0  << Error - Invalid bank
SYM  8DF2  << Error - Invalid bank
SYM  8DF4  << Error - Invalid bank
SYM  8DF6  << Error - Invalid bank
SYM  8DF8  << Error - Invalid bank
SYM  8DFA  << Error - Invalid bank
SYM  8DFC  << Error - Invalid bank
SYM  8DFE  << Error - Invalid bank
SYM  8E00  << Error - Invalid bank
SYM  8E02  << Error - Invalid bank
SYM  8E04  << Error - Invalid bank
SYM  8E06  << Error - Invalid bank
SYM  8E08  << Error - Invalid bank
SYM  8E0A  << Error - Invalid bank
SYM  8E0C  << Error - Invalid bank
SYM  8E0E  << Error - Invalid bank
SYM  8E10  << Error - Invalid bank
SYM  8E12  << Error - Invalid bank
SYM  8E14  << Error - Invalid bank
SYM  8E16  << Error - Invalid bank
SYM  8E18  << Error - Invalid bank
SYM  8E1A  << Error - Invalid bank
SYM  8E1C  << Error - Invalid bank
SYM  8E1E  << Error - Invalid bank
SYM  8E20  << Error - Invalid bank
SYM  8E22  << Error - Invalid bank
SYM  8E24  << Error - Invalid bank
SYM  8E26  << Error - Invalid bank
SYM  8E28  << Error - Invalid bank
SYM  8E2A  << Error - Invalid bank
SYM  8E2C  << Error - Invalid bank
SYM  8E2E  << Error - Invalid bank
SYM  8E30  << Error - Invalid bank
SYM  8E32  << Error - Invalid bank
SYM  8E34  << Error - Invalid bank
SYM  8E36  << Error - Invalid bank
SYM  8E38  << Error - Invalid bank
SYM  8E3A  << Error - Invalid bank
SYM  8E3C  << Error - Invalid bank
SYM  8E3E  << Error - Invalid bank
SYM  8E40  << Error - Invalid bank
SYM  8E42  << Error - Invalid bank
SYM  8E44  << Error - Invalid bank
SYM  8E46  << Error - Invalid bank
SYM  8E48  << Error - Invalid bank
SYM  8E4A  << Error - Invalid bank
SYM  8E4C  << Error - Invalid bank
SYM  8E4E  << Error - Invalid bank
SYM  8E50  << Error - Invalid bank
SYM  8E52  << Error - Invalid bank
SYM  8E54  << Error - Invalid bank
SYM  8E56  << Error - Invalid bank
SYM  8E58  << Error - Invalid bank
SYM  8E5A  << Error - Invalid bank
SYM  8E5C  << Error - Invalid bank
SYM  8E5E  << Error - Invalid bank
SYM  8E60  << Error - Invalid bank
SYM  8E62  << Error - Invalid bank
SYM  8E64  << Error - Invalid bank
SYM  8E66  << Error - Invalid bank
SYM  8E68  << Error - Invalid bank
SYM  8E6A  << Error - Invalid bank
SYM  8E6C  << Error - Invalid bank
SYM  8E6E  << Error - Invalid bank
SYM  8E70  << Error - Invalid bank
SYM  8E72  << Error - Invalid bank
SYM  8E74  << Error - Invalid bank
SYM  8E76  << Error - Invalid bank
SYM  8E78  << Error - Invalid bank
SYM  8E7A  << Error - Invalid bank
SYM  8E7C  << Error - Invalid bank
SYM  8E7E  << Error - Invalid bank
SYM  8E80  << Error - Invalid bank
SYM  8E82  << Error - Invalid bank
SYM  8E84  << Error - Invalid bank
SYM  8E86  << Error - Invalid bank
SYM  8E88  << Error - Invalid bank
SYM  8E8A  << Error - Invalid bank
SYM  8E8C  << Error - Invalid bank
SYM  8E8E  << Error - Invalid bank
SYM  8E90  << Error - Invalid bank
SYM  8E92  << Error - Invalid bank
SYM  8E94  << Error - Invalid bank
SYM  8E96  << Error - Invalid bank
SYM  8E98  << Error - Invalid bank
SYM  8E9A  << Error - Invalid bank
SYM  8E9C  << Error - Invalid bank
SYM  8E9E  << Error - Invalid bank
SYM  8EA0  << Error - Invalid bank
SYM  8EA2  << Error - Invalid bank
SYM  8EA4  << Error - Invalid bank
SYM  8EA6  << Error - Invalid bank
SYM  8EA8  << Error - Invalid bank
SYM  8EAA  << Error - Invalid bank
SYM  8EAC  << Error - Invalid bank
SYM  8EAE  << Error - Invalid bank
SYM  8EB0  << Error - Invalid bank
SYM  8EB2  << Error - Invalid bank
SYM  8EB4  << Error - Invalid bank
SYM  8EB6  << Error - Invalid bank
SYM  8EB8  << Error - Invalid bank
SYM  8EBA  << Error - Invalid bank
SYM  8EBC  << Error - Invalid bank
SYM  8EBE  << Error - Invalid bank
SYM  8EC0  << Error - Invalid bank
SYM  8EC2  << Error - Invalid bank
SYM  8EC4  << Error - Invalid bank
SYM  8EC6  << Error - Invalid bank
SYM  8EC8  << Error - Invalid bank
SYM  8ECA  << Error - Invalid bank
SYM  8ECC  << Error - Invalid bank
SYM  8ECE  << Error - Invalid bank
SYM  8ED0  << Error - Invalid bank
SYM  8ED2  << Error - Invalid bank
SYM  8ED4  << Error - Invalid bank
SYM  8ED6  << Error - Invalid bank
SYM  8ED8  << Error - Invalid bank
SYM  8EDA  << Error - Invalid bank
SYM  8EDC  << Error - Invalid bank
SYM  8EDE  << Error - Invalid bank
SYM  8EE0  << Error - Invalid bank
SYM  8EE2  << Error - Invalid bank
SYM  8EE4  << Error - Invalid bank
SYM  8EE6  << Error - Invalid bank
SYM  8EE8  << Error - Invalid bank
SYM  8EEA  << Error - Invalid bank
SYM  8EEC  << Error - Invalid bank
SYM  8EEE  << Error - Invalid bank
SYM  8EF0  << Error - Invalid bank
SYM  8EF2  << Error - Invalid bank
SYM  8EF4  << Error - Invalid bank
SYM  8EF6  << Error - Invalid bank
SYM  8EF8  << Error - Invalid bank
SYM  8EFA  << Error - Invalid bank
SYM  8EFC  << Error - Invalid bank
SYM  8EFE  << Error - Invalid bank
SYM  8F00  << Error - Invalid bank
SYM  8F02  << Error - Invalid bank
SYM  8F04  << Error - Invalid bank
SYM  8F06  << Error - Invalid bank
SYM  8F08  << Error - Invalid bank
SYM  8F0A  << Error - Invalid bank
SYM  8F0C  << Error - Invalid bank
SYM  8F0E  << Error - Invalid bank
SYM  8F10  << Error - Invalid bank
SYM  8F12  << Error - Invalid bank
SYM  8F14  << Error - Invalid bank
SYM  8F16  << Error - Invalid bank
SYM  8F18  << Error - Invalid bank
SYM  8F1A  << Error - Invalid bank
SYM  8F1C  << Error - Invalid bank
BYT  AFBD  << Error - Invalid bank
BYT  AFBE  << Error - Invalid bank
SYM  F000  << Error - Invalid bank
SYM  F002  << Error - Invalid bank
SYM  F004  << Error - Invalid bank
SYM  F008  << Error - Invalid bank
SYM  F00C  << Error - Invalid bank
SYM  F00E  << Error - Invalid bank
SYM  F010  << Error - Invalid bank
SYM  F012  << Error - Invalid bank
SYM  F014  << Error - Invalid bank
SYM  F016  << Error - Invalid bank
SYM  F018  << Error - Invalid bank
SYM  F01A  << Error - Invalid bank
SYM  F01C  << Error - Invalid bank
SYM  F01E  << Error - Invalid bank
SYM  F020  << Error - Invalid bank
SYM  F022  << Error - Invalid bank
SYM  F024  << Error - Invalid bank
SYM  F026  << Error - Invalid bank
SYM  F028  << Error - Invalid bank
SYM  F02A  << Error - Invalid bank
SYM  F02C  << Error - Invalid bank
SYM  F02E  << Error - Invalid bank
SYM  F02F  << Error - Invalid bank
SYM  F030  << Error - Invalid bank
SYM  F031  << Error - Invalid bank
SYM  F032  << Error - Invalid bank
SYM  F033  << Error - Invalid bank
SYM  F034  << Error - Invalid bank
SYM  F036  << Error - Invalid bank
SYM  F038  << Error - Invalid bank
SYM  F03A  << Error - Invalid bank
SYM  F03C  << Error - Invalid bank
SYM  F03E  << Error - Invalid bank
SYM  F03F  << Error - Invalid bank
SYM  F048  << Error - Invalid bank
SYM  F049  << Error - Invalid bank
SYM  F04A  << Error - Invalid bank
SYM  F04B  << Error - Invalid bank
SYM  F04C  << Error - Invalid bank
SYM  F04E  << Error - Invalid bank
SYM  F050  << Error - Invalid bank
SYM  F052  << Error - Invalid bank
SYM  F054  << Error - Invalid bank
SYM  F056  << Error - Invalid bank
SYM  F058  << Error - Invalid bank
SYM  F05A  << Error - Invalid bank
SYM  F05C  << Error - Invalid bank
SYM  F05E  << Error - Invalid bank
SYM  F060  << Error - Invalid bank
SYM  F062  << Error - Invalid bank
SYM  F064  << Error - Invalid bank
SYM  F065  << Error - Invalid bank
SYM  F066  << Error - Invalid bank
SYM  F067  << Error - Invalid bank
SYM  F068  << Error - Invalid bank
SYM  F069  << Error - Invalid bank
SYM  F06A  << Error - Invalid bank
SYM  F06B  << Error - Invalid bank
SYM  F06C  << Error - Invalid bank
SYM  F06E  << Error - Invalid bank
SYM  F070  << Error - Invalid bank
SYM  F072  << Error - Invalid bank
SYM  F074  << Error - Invalid bank
SYM  F076  << Error - Invalid bank
SYM  F078  << Error - Invalid bank
SYM  F07A  << Error - Invalid bank
SYM  F07C  << Error - Invalid bank
SYM  F07E  << Error - Invalid bank
SYM  F080  << Error - Invalid bank
SYM  F082  << Error - Invalid bank
SYM  F084  << Error - Invalid bank
SYM  F086  << Error - Invalid bank
SYM  F088  << Error - Invalid bank
SYM  F08A  << Error - Invalid bank
SYM  F08C  << Error - Invalid bank
SYM  F08E  << Error - Invalid bank
SYM  F090  << Error - Invalid bank
SYM  F092  << Error - Invalid bank
SYM  F094  << Error - Invalid bank
SYM  F096  << Error - Invalid bank
SYM  F098  << Error - Invalid bank
SYM  F09A  << Error - Invalid bank
SYM  F09C  << Error - Invalid bank
SYM  F09E  << Error - Invalid bank
SYM  F0A0  << Error - Invalid bank
SYM  F0A2  << Error - Invalid bank
SYM  F0A4  << Error - Invalid bank
SYM  F0A6  << Error - Invalid bank
SYM  F0A8  << Error - Invalid bank
SYM  F0AA  << Error - Invalid bank
SYM  F0AC  << Error - Invalid bank
SYM  F0AE  << Error - Invalid bank
SYM  F0B0  << Error - Invalid bank
SYM  F0B2  << Error - Invalid bank
SYM  F0B4  << Error - Invalid bank
SYM  F0B5  << Error - Invalid bank
SYM  F0B6  << Error - Invalid bank
SYM  F0B8  << Error - Invalid bank
SYM  F0BA  << Error - Invalid bank
SYM  F0BC  << Error - Invalid bank
SYM  F0BE  << Error - Invalid bank
SYM  F0C0  << Error - Invalid bank
SYM  F0C2  << Error - Invalid bank
SYM  F0C4  << Error - Invalid bank
SYM  F0C6  << Error - Invalid bank
SYM  F0C8  << Error - Invalid bank
SYM  F0CA  << Error - Invalid bank
SYM  F0CC  << Error - Invalid bank
SYM  F0CE  << Error - Invalid bank
SYM  F0D0  << Error - Invalid bank
SYM  F0D2  << Error - Invalid bank
SYM  F0D4  << Error - Invalid bank
SYM  F0D6  << Error - Invalid bank
SYM  F0D8  << Error - Invalid bank
SYM  F0DA  << Error - Invalid bank
SYM  F0DC  << Error - Invalid bank
SYM  F0DE  << Error - Invalid bank
SYM  F0E0  << Error - Invalid bank
SYM  F0E1  << Error - Invalid bank
SYM  F0E2  << Error - Invalid bank
SYM  F0E4  << Error - Invalid bank
SYM  F0E6  << Error - Invalid bank
SYM  F0E8  << Error - Invalid bank
SYM  F0EA  << Error - Invalid bank
SYM  F0EC  << Error - Invalid bank
SYM  F0ED  << Error - Invalid bank
SYM  F0EE  << Error - Invalid bank
SYM  F0F0  << Error - Invalid bank
SYM  F0F2  << Error - Invalid bank
SYM  F0F4  << Error - Invalid bank
SYM  F0F6  << Error - Invalid bank
SYM  F0F8  << Error - Invalid bank
SYM  F0FA  << Error - Invalid bank
SYM  F0FC  << Error - Invalid bank
SYM  F0FE  << Error - Invalid bank
SYM  F100  << Error - Invalid bank
SYM  F102  << Error - Invalid bank
SYM  F104  << Error - Invalid bank
SYM  F106  << Error - Invalid bank
SYM  F108  << Error - Invalid bank
SYM  F10A  << Error - Invalid bank
SYM  F10C  << Error - Invalid bank
SYM  F10E  << Error - Invalid bank
SYM  F110  << Error - Invalid bank
SYM  F112  << Error - Invalid bank
SYM  F114  << Error - Invalid bank
SYM  F115  << Error - Invalid bank
SYM  F116  << Error - Invalid bank
SYM  F118  << Error - Invalid bank
SYM  F11A  << Error - Invalid bank
SYM  F11C  << Error - Invalid bank
SYM  F11E  << Error - Invalid bank
SYM  F120  << Error - Invalid bank
SYM  F122  << Error - Invalid bank
SYM  F124  << Error - Invalid bank
SYM  F126  << Error - Invalid bank
SYM  F128  << Error - Invalid bank
SYM  F12A  << Error - Invalid bank
SYM  F12C  << Error - Invalid bank
SYM  F12E  << Error - Invalid bank
SYM  F130  << Error - Invalid bank
SYM  F132  << Error - Invalid bank
SYM  F134  << Error - Invalid bank
SYM  F136  << Error - Invalid bank
SYM  F138  << Error - Invalid bank
SYM  F13A  << Error - Invalid bank
SYM  F13B  << Error - Invalid bank
SYM  F13C  << Error - Invalid bank
SYM  F13D  << Error - Invalid bank
SYM  F13E  << Error - Invalid bank
SYM  F13F  << Error - Invalid bank
SYM  F140  << Error - Invalid bank
SYM  F141  << Error - Invalid bank
SYM  F142  << Error - Invalid bank
SYM  F143  << Error - Invalid bank
SYM  F144  << Error - Invalid bank
SYM  F145  << Error - Invalid bank
SYM  F146  << Error - Invalid bank
SYM  F148  << Error - Invalid bank
SYM  F14A  << Error - Invalid bank
SYM  F14B  << Error - Invalid bank
SYM  F14C  << Error - Invalid bank
SYM  F14D  << Error - Invalid bank
SYM  F14E  << Error - Invalid bank
SYM  F150  << Error - Invalid bank
SYM  F152  << Error - Invalid bank
SYM  F154  << Error - Invalid bank
SYM  F155  << Error - Invalid bank
SYM  F156  << Error - Invalid bank
SYM  F158  << Error - Invalid bank
SYM  F15A  << Error - Invalid bank
SYM  F15C  << Error - Invalid bank
SYM  F15E  << Error - Invalid bank
SYM  F160  << Error - Invalid bank
SYM  F162  << Error - Invalid bank
SYM  F164  << Error - Invalid bank
SYM  F166  << Error - Invalid bank
SYM  F167  << Error - Invalid bank
SYM  F168  << Error - Invalid bank
SYM  F169  << Error - Invalid bank
SYM  F16A  << Error - Invalid bank
SYM  F16B  << Error - Invalid bank
SYM  F16C  << Error - Invalid bank
SYM  F16D  << Error - Invalid bank
SYM  F16E  << Error - Invalid bank
SYM  F170  << Error - Invalid bank
SYM  F172  << Error - Invalid bank
SYM  F174  << Error - Invalid bank
SYM  F176  << Error - Invalid bank
SYM  F177  << Error - Invalid bank
SYM  F178  << Error - Invalid bank
SYM  F17A  << Error - Invalid bank
SYM  F17C  << Error - Invalid bank
SYM  F17E  << Error - Invalid bank
SYM  F180  << Error - Invalid bank
SYM  F182  << Error - Invalid bank
SYM  F184  << Error - Invalid bank
SYM  F186  << Error - Invalid bank
SYM  F187  << Error - Invalid bank
SYM  F188  << Error - Invalid bank
SYM  F18A  << Error - Invalid bank
SYM  F18C  << Error - Invalid bank
SYM  F18E  << Error - Invalid bank
SYM  F190  << Error - Invalid bank
SYM  F192  << Error - Invalid bank
SYM  F193  << Error - Invalid bank
SYM  F194  << Error - Invalid bank
SYM  F196  << Error - Invalid bank
SYM  F198  << Error - Invalid bank
SYM  F19A  << Error - Invalid bank
SYM  F19C  << Error - Invalid bank
SYM  F19E  << Error - Invalid bank
SYM  F1A0  << Error - Invalid bank
SYM  F1A2  << Error - Invalid bank
SYM  F1A4  << Error - Invalid bank
SYM  F1A6  << Error - Invalid bank
SYM  F1A7  << Error - Invalid bank
SYM  F1A8  << Error - Invalid bank
SYM  F1A9  << Error - Invalid bank
SYM  F1AA  << Error - Invalid bank
SYM  F1AC  << Error - Invalid bank
SYM  F1AE  << Error - Invalid bank
SYM  F1B0  << Error - Invalid bank
SYM  F1B2  << Error - Invalid bank
SYM  F1B4  << Error - Invalid bank
SYM  F1B6  << Error - Invalid bank
SYM  F1B8  << Error - Invalid bank
SYM  F1B9  << Error - Invalid bank
SYM  F1BA  << Error - Invalid bank
SYM  F1BC  << Error - Invalid bank
SYM  F1BE  << Error - Invalid bank
SYM  F1BF  << Error - Invalid bank
SYM  F1C0  << Error - Invalid bank
SYM  F1C2  << Error - Invalid bank
SYM  F1C4  << Error - Invalid bank
SYM  F1C6  << Error - Invalid bank
SYM  F1C8  << Error - Invalid bank
SYM  F1CA  << Error - Invalid bank
SYM  F1CC  << Error - Invalid bank
SYM  F1CE  << Error - Invalid bank
SYM  F1D0  << Error - Invalid bank
SYM  F1D2  << Error - Invalid bank
SYM  F1D4  << Error - Invalid bank
SYM  F1D6  << Error - Invalid bank
SYM  F1D8  << Error - Invalid bank
SYM  F1DA  << Error - Invalid bank
SYM  F1DC  << Error - Invalid bank
SYM  F1DE  << Error - Invalid bank
SYM  F1E0  << Error - Invalid bank
SYM  F1E2  << Error - Invalid bank
SYM  F1E4  << Error - Invalid bank
SYM  F1E6  << Error - Invalid bank
SYM  F1E7  << Error - Invalid bank
SYM  F1E8  << Error - Invalid bank
SYM  F1EA  << Error - Invalid bank
SYM  F1EC  << Error - Invalid bank
SYM  F1EE  << Error - Invalid bank
SYM  F1F0  << Error - Invalid bank
SYM  F1F2  << Error - Invalid bank
SYM  F1F3  << Error - Invalid bank
SYM  F1F4  << Error - Invalid bank
SYM  F1F5  << Error - Invalid bank
SYM  F1F6  << Error - Invalid bank
SYM  F1F7  << Error - Invalid bank
SYM  F1F8  << Error - Invalid bank
SYM  F1F9  << Error - Invalid bank
SYM  F1FA  << Error - Invalid bank
SYM  F1FB  << Error - Invalid bank
SYM  F1FC  << Error - Invalid bank
SYM  F1FE  << Error - Invalid bank
SYM  F200  << Error - Invalid bank
SYM  F202  << Error - Invalid bank
SYM  F203  << Error - Invalid bank
SYM  F204  << Error - Invalid bank
SYM  F205  << Error - Invalid bank
SYM  F206  << Error - Invalid bank
SYM  F207  << Error - Invalid bank
SYM  F208  << Error - Invalid bank
SYM  F209  << Error - Invalid bank
SYM  F20A  << Error - Invalid bank
SYM  F20B  << Error - Invalid bank
SYM  F20C  << Error - Invalid bank
SYM  F20D  << Error - Invalid bank
SYM  F20E  << Error - Invalid bank
SYM  F20F  << Error - Invalid bank
SYM  F210  << Error - Invalid bank
SYM  F211  << Error - Invalid bank
SYM  F212  << Error - Invalid bank
SYM  F214  << Error - Invalid bank
SYM  F216  << Error - Invalid bank
SYM  F218  << Error - Invalid bank
SYM  F219  << Error - Invalid bank
SYM  F21A  << Error - Invalid bank
SYM  F21C  << Error - Invalid bank
SYM  F21E  << Error - Invalid bank
SYM  F220  << Error - Invalid bank
SYM  F221  << Error - Invalid bank
SYM  F222  << Error - Invalid bank
SYM  F223  << Error - Invalid bank
SYM  F224  << Error - Invalid bank
SYM  F225  << Error - Invalid bank
SYM  F226  << Error - Invalid bank
SYM  F227  << Error - Invalid bank
SYM  F228  << Error - Invalid bank
SYM  F22A  << Error - Invalid bank
SYM  F22C  << Error - Invalid bank
SYM  F22D  << Error - Invalid bank
SYM  F22E  << Error - Invalid bank
SYM  F230  << Error - Invalid bank
SYM  F232  << Error - Invalid bank
SYM  F234  << Error - Invalid bank
SYM  F236  << Error - Invalid bank
SYM  F238  << Error - Invalid bank
SYM  F23A  << Error - Invalid bank
SYM  F23C  << Error - Invalid bank
SYM  F23E  << Error - Invalid bank
SYM  F240  << Error - Invalid bank
SYM  F242  << Error - Invalid bank
SYM  F244  << Error - Invalid bank
SYM  F246  << Error - Invalid bank
SYM  F248  << Error - Invalid bank
SYM  F249  << Error - Invalid bank
SYM  F24A  << Error - Invalid bank
SYM  F24B  << Error - Invalid bank
SYM  F24C  << Error - Invalid bank
SYM  F24D  << Error - Invalid bank
SYM  F24E  << Error - Invalid bank
SYM  F24F  << Error - Invalid bank
SYM  F250  << Error - Invalid bank
SYM  F251  << Error - Invalid bank
SYM  F252  << Error - Invalid bank
SYM  F253  << Error - Invalid bank
SYM  F254  << Error - Invalid bank
SYM  F256  << Error - Invalid bank
SYM  F258  << Error - Invalid bank
SYM  F25A  << Error - Invalid bank
SYM  F25C  << Error - Invalid bank
SYM  F25E  << Error - Invalid bank
SYM  F260  << Error - Invalid bank
SYM  F262  << Error - Invalid bank
SYM  F264  << Error - Invalid bank
SYM  F265  << Error - Invalid bank
SYM  F266  << Error - Invalid bank
SYM  F267  << Error - Invalid bank
SYM  F268  << Error - Invalid bank
SYM  F26A  << Error - Invalid bank
SYM  F26C  << Error - Invalid bank
SYM  F26E  << Error - Invalid bank
SYM  F270  << Error - Invalid bank
SYM  F272  << Error - Invalid bank
SYM  F274  << Error - Invalid bank
SYM  F276  << Error - Invalid bank
SYM  F277  << Error - Invalid bank
SYM  F278  << Error - Invalid bank
SYM  F279  << Error - Invalid bank
SYM  F27A  << Error - Invalid bank
SYM  F27B  << Error - Invalid bank
SYM  F27C  << Error - Invalid bank
SYM  F27D  << Error - Invalid bank
SYM  F27E  << Error - Invalid bank
SYM  F280  << Error - Invalid bank
SYM  F282  << Error - Invalid bank
SYM  F283  << Error - Invalid bank
SYM  F284  << Error - Invalid bank
SYM  F286  << Error - Invalid bank
SYM  F288  << Error - Invalid bank
SYM  F28A  << Error - Invalid bank
SYM  F28C  << Error - Invalid bank
SYM  F28E  << Error - Invalid bank
SYM  F290  << Error - Invalid bank
SYM  F291  << Error - Invalid bank
SYM  F292  << Error - Invalid bank
SYM  F294  << Error - Invalid bank
SYM  F296  << Error - Invalid bank
SYM  F298  << Error - Invalid bank
SYM  F29A  << Error - Invalid bank
SYM  F29B  << Error - Invalid bank
SYM  F29C  << Error - Invalid bank
SYM  F29E  << Error - Invalid bank
SYM  F2A0  << Error - Invalid bank
SYM  F2A2  << Error - Invalid bank
SYM  F2A3  << Error - Invalid bank
SYM  F2A4  << Error - Invalid bank
SYM  F2A5  << Error - Invalid bank
SYM  F2A6  << Error - Invalid bank
SYM  F2A7  << Error - Invalid bank
SYM  F2A8  << Error - Invalid bank
SYM  F2A9  << Error - Invalid bank
SYM  F2AA  << Error - Invalid bank
SYM  F2AB  << Error - Invalid bank
SYM  F2AC  << Error - Invalid bank
SYM  F2AD  << Error - Invalid bank
SYM  F2AE  << Error - Invalid bank
SYM  F2AF  << Error - Invalid bank
SYM  F2B0  << Error - Invalid bank
SYM  F2B1  << Error - Invalid bank
SYM  F2B2  << Error - Invalid bank
SYM  F2B3  << Error - Invalid bank
SYM  F2B4  << Error - Invalid bank
SYM  F2B6  << Error - Invalid bank
SYM  F2B7  << Error - Invalid bank
SYM  F2B8  << Error - Invalid bank
SYM  F2B9  << Error - Invalid bank
SYM  F2BA  << Error - Invalid bank
SYM  F2BB  << Error - Invalid bank
SYM  F2BC  << Error - Invalid bank
SYM  F2BD  << Error - Invalid bank
SYM  F2BE  << Error - Invalid bank
SYM  F2BF  << Error - Invalid bank
SYM  F2C0  << Error - Invalid bank
SYM  F2C2  << Error - Invalid bank
SYM  F2C4  << Error - Invalid bank
SYM  F2C8  << Error - Invalid bank
SYM  F2CC  << Error - Invalid bank
SYM  F2D0  << Error - Invalid bank
SYM  F2D4  << Error - Invalid bank
SYM  F2D8  << Error - Invalid bank
SYM  F2DC  << Error - Invalid bank
SYM  F2DD  << Error - Invalid bank
SYM  F2DE  << Error - Invalid bank
SYM  F2DF  << Error - Invalid bank
SYM  F2E0  << Error - Invalid bank
SYM  F2E2  << Error - Invalid bank
SYM  F2E4  << Error - Invalid bank
SYM  F2E6  << Error - Invalid bank
SYM  F2E8  << Error - Invalid bank
SYM  F2EA  << Error - Invalid bank
SYM  F2EC  << Error - Invalid bank
SYM  F2EE  << Error - Invalid bank
SYM  F2F0  << Error - Invalid bank
SYM  F2F2  << Error - Invalid bank
SYM  F2F4  << Error - Invalid bank
SYM  F2F6  << Error - Invalid bank
SYM  F2F8  << Error - Invalid bank
SYM  F2FA  << Error - Invalid bank
SYM  F2FC  << Error - Invalid bank
SYM  F2FE  << Error - Invalid bank
SYM  F300  << Error - Invalid bank
SYM  F302  << Error - Invalid bank
SYM  F304  << Error - Invalid bank
SYM  F306  << Error - Invalid bank
SYM  F308  << Error - Invalid bank
SYM  F30A  << Error - Invalid bank
SYM  F30C  << Error - Invalid bank
SYM  F30E  << Error - Invalid bank
SYM  F30F  << Error - Invalid bank
SYM  F310  << Error - Invalid bank
SYM  F311  << Error - Invalid bank
SYM  F312  << Error - Invalid bank
SYM  F314  << Error - Invalid bank
SYM  F316  << Error - Invalid bank
SYM  F317  << Error - Invalid bank
SYM  F318  << Error - Invalid bank
SYM  F319  << Error - Invalid bank
SYM  F31A  << Error - Invalid bank
SYM  F31C  << Error - Invalid bank
SYM  F31E  << Error - Invalid bank
SYM  F320  << Error - Invalid bank
SYM  F322  << Error - Invalid bank
SYM  F324  << Error - Invalid bank
SYM  F326  << Error - Invalid bank
SYM  F328  << Error - Invalid bank
SYM  F32A  << Error - Invalid bank
SYM  F32B  << Error - Invalid bank
SYM  F32C  << Error - Invalid bank
SYM  F32E  << Error - Invalid bank
SYM  F330  << Error - Invalid bank
SYM  F332  << Error - Invalid bank
SYM  F334  << Error - Invalid bank
SYM  F336  << Error - Invalid bank
SYM  F338  << Error - Invalid bank
SYM  F33A  << Error - Invalid bank
SYM  F33C  << Error - Invalid bank
SYM  F33E  << Error - Invalid bank
SYM  F340  << Error - Invalid bank
SYM  F342  << Error - Invalid bank
SYM  F343  << Error - Invalid bank
SYM  F344  << Error - Invalid bank
SYM  F346  << Error - Invalid bank
SYM  F348  << Error - Invalid bank
SYM  F34A  << Error - Invalid bank
SYM  F34C  << Error - Invalid bank
SYM  F34E  << Error - Invalid bank
SYM  F350  << Error - Invalid bank
SYM  F352  << Error - Invalid bank
SYM  F354  << Error - Invalid bank
SYM  F355  << Error - Invalid bank
SYM  F356  << Error - Invalid bank
SYM  F357  << Error - Invalid bank
SYM  F358  << Error - Invalid bank
SYM  F359  << Error - Invalid bank
SYM  F35A  << Error - Invalid bank
SYM  F35B  << Error - Invalid bank
SYM  F35C  << Error - Invalid bank
SYM  F35E  << Error - Invalid bank
SYM  F360  << Error - Invalid bank
SYM  F362  << Error - Invalid bank
SYM  F364  << Error - Invalid bank
SYM  F366  << Error - Invalid bank
SYM  F368  << Error - Invalid bank
SYM  F36A  << Error - Invalid bank
SYM  F36C  << Error - Invalid bank
SYM  F36E  << Error - Invalid bank
SYM  F370  << Error - Invalid bank
SYM  F372  << Error - Invalid bank
SYM  F374  << Error - Invalid bank
SYM  F376  << Error - Invalid bank
SYM  F377  << Error - Invalid bank
SYM  F378  << Error - Invalid bank
SYM  F37A  << Error - Invalid bank
SYM  F37C  << Error - Invalid bank
SYM  F37E  << Error - Invalid bank
SYM  F380  << Error - Invalid bank
SYM  F382  << Error - Invalid bank
SYM  F384  << Error - Invalid bank
SYM  F386  << Error - Invalid bank
SYM  F388  << Error - Invalid bank
SYM  F38A  << Error - Invalid bank
SYM  F38C  << Error - Invalid bank
SYM  F38D  << Error - Invalid bank
SYM  F38E  << Error - Invalid bank
SYM  F38F  << Error - Invalid bank
SYM  F390  << Error - Invalid bank
SYM  F391  << Error - Invalid bank
SYM  F392  << Error - Invalid bank
SYM  F393  << Error - Invalid bank
SYM  F394  << Error - Invalid bank
SYM  F396  << Error - Invalid bank
SYM  F398  << Error - Invalid bank
SYM  F39A  << Error - Invalid bank
SYM  F39C  << Error - Invalid bank
SYM  F39E  << Error - Invalid bank
SYM  F3A0  << Error - Invalid bank
SYM  F3A1  << Error - Invalid bank
SYM  F3A2  << Error - Invalid bank
SYM  F3A3  << Error - Invalid bank
SYM  F3A4  << Error - Invalid bank
SYM  F3A5  << Error - Invalid bank
SYM  F3A6  << Error - Invalid bank
SYM  F3A8  << Error - Invalid bank
SYM  F3A9  << Error - Invalid bank
SYM  F3AA  << Error - Invalid bank
SYM  F3AB  << Error - Invalid bank
SYM  F3AC  << Error - Invalid bank
SYM  F3AD  << Error - Invalid bank
SYM  F3AE  << Error - Invalid bank
SYM  F3AF  << Error - Invalid bank
SYM  F3B0  << Error - Invalid bank
SYM  F3B2  << Error - Invalid bank
SYM  F3B4  << Error - Invalid bank
SYM  F3B6  << Error - Invalid bank
SYM  F3B8  << Error - Invalid bank
SYM  F3BA  << Error - Invalid bank
SYM  F3BC  << Error - Invalid bank
SYM  F3BE  << Error - Invalid bank
SYM  F3C0  << Error - Invalid bank
SYM  F3C1  << Error - Invalid bank
SYM  F3C2  << Error - Invalid bank
SYM  F3C3  << Error - Invalid bank
SYM  F3C4  << Error - Invalid bank
SYM  F3C6  << Error - Invalid bank
SYM  F3C8  << Error - Invalid bank
SYM  F3CA  << Error - Invalid bank
SYM  F3CC  << Error - Invalid bank
SYM  F3CE  << Error - Invalid bank
SYM  F3D0  << Error - Invalid bank
SYM  F3D2  << Error - Invalid bank
SYM  F3D4  << Error - Invalid bank
SYM  F3D6  << Error - Invalid bank
SYM  F3D8  << Error - Invalid bank
SYM  F3DA  << Error - Invalid bank
SYM  F3DC  << Error - Invalid bank
SYM  F3DE  << Error - Invalid bank
SYM  F3E0  << Error - Invalid bank
SYM  F3E2  << Error - Invalid bank
SYM  F3E4  << Error - Invalid bank
SYM  F3E6  << Error - Invalid bank
SYM  F3E8  << Error - Invalid bank
SYM  F3EA  << Error - Invalid bank
SYM  F3EC  << Error - Invalid bank
SYM  F3EE  << Error - Invalid bank
SYM  F3F0  << Error - Invalid bank
SYM  F3F2  << Error - Invalid bank
SYM  F3F4  << Error - Invalid bank
SYM  F3F5  << Error - Invalid bank
SYM  F3F6  << Error - Invalid bank
SYM  F3F7  << Error - Invalid bank
SYM  F3F8  << Error - Invalid bank
SYM  F3F9  << Error - Invalid bank
SYM  F3FA  << Error - Invalid bank
SYM  F3FB  << Error - Invalid bank
SYM  F3FC  << Error - Invalid bank
SYM  F3FD  << Error - Invalid bank
SYM  F3FE  << Error - Invalid bank
SYM  F3FF  << Error - Invalid bank
SYM  F400  << Error - Invalid bank
SYM  F401  << Error - Invalid bank
SYM  F402  << Error - Invalid bank
SYM  F404  << Error - Invalid bank
SYM  F405  << Error - Invalid bank
SYM  F406  << Error - Invalid bank
SYM  F407  << Error - Invalid bank
SYM  F408  << Error - Invalid bank
SYM  F409  << Error - Invalid bank
SYM  F40A  << Error - Invalid bank
SYM  F40B  << Error - Invalid bank
SYM  F40C  << Error - Invalid bank
SYM  F40D  << Error - Invalid bank
SYM  F40E  << Error - Invalid bank
SYM  F40F  << Error - Invalid bank
SYM  F410  << Error - Invalid bank
SYM  F411  << Error - Invalid bank
SYM  F412  << Error - Invalid bank
SYM  F413  << Error - Invalid bank
SYM  F414  << Error - Invalid bank
SYM  F415  << Error - Invalid bank
SYM  F416  << Error - Invalid bank
SYM  F417  << Error - Invalid bank
SYM  F418  << Error - Invalid bank
SYM  F419  << Error - Invalid bank
SYM  F41A  << Error - Invalid bank
SYM  F41B  << Error - Invalid bank
SYM  F41C  << Error - Invalid bank
SYM  F41D  << Error - Invalid bank
SYM  F41E  << Error - Invalid bank
SYM  F41F  << Error - Invalid bank
SYM  F420  << Error - Invalid bank
SYM  F421  << Error - Invalid bank
SYM  F422  << Error - Invalid bank
SYM  F423  << Error - Invalid bank
SYM  F424  << Error - Invalid bank
SYM  F425  << Error - Invalid bank
SYM  F426  << Error - Invalid bank
SYM  F427  << Error - Invalid bank
SYM  F428  << Error - Invalid bank
SYM  F429  << Error - Invalid bank
SYM  F42A  << Error - Invalid bank
SYM  F42B  << Error - Invalid bank
SYM  F42C  << Error - Invalid bank
SYM  F42D  << Error - Invalid bank
SYM  F42E  << Error - Invalid bank
SYM  F42F  << Error - Invalid bank
SYM  F430  << Error - Invalid bank
SYM  F431  << Error - Invalid bank
SYM  F432  << Error - Invalid bank
SYM  F433  << Error - Invalid bank
SYM  F434  << Error - Invalid bank
SYM  F435  << Error - Invalid bank
SYM  F436  << Error - Invalid bank
SYM  F437  << Error - Invalid bank
SYM  F438  << Error - Invalid bank
SYM  F439  << Error - Invalid bank
SYM  F43A  << Error - Invalid bank
SYM  F43B  << Error - Invalid bank
SYM  F43C  << Error - Invalid bank
SYM  F43E  << Error - Invalid bank
SYM  F43F  << Error - Invalid bank
SYM  F440  << Error - Invalid bank
SYM  F441  << Error - Invalid bank
SYM  F442  << Error - Invalid bank
SYM  F443  << Error - Invalid bank
SYM  F444  << Error - Invalid bank
SYM  F445  << Error - Invalid bank
SYM  F446  << Error - Invalid bank
SYM  F448  << Error - Invalid bank
SYM  F44A  << Error - Invalid bank
SYM  F44B  << Error - Invalid bank
SYM  F44C  << Error - Invalid bank
SYM  F44D  << Error - Invalid bank
SYM  F44E  << Error - Invalid bank
SYM  F44F  << Error - Invalid bank
SYM  F450  << Error - Invalid bank
SYM  F451  << Error - Invalid bank
SYM  F452  << Error - Invalid bank
SYM  F453  << Error - Invalid bank
SYM  F454  << Error - Invalid bank
SYM  F455  << Error - Invalid bank
SYM  F456  << Error - Invalid bank
SYM  F458  << Error - Invalid bank
SYM  F45A  << Error - Invalid bank
SYM  F45C  << Error - Invalid bank
SYM  F45E  << Error - Invalid bank
SYM  F460  << Error - Invalid bank
SYM  F462  << Error - Invalid bank
SYM  F464  << Error - Invalid bank
SYM  F466  << Error - Invalid bank
SYM  F468  << Error - Invalid bank
SYM  F46A  << Error - Invalid bank
SYM  F46C  << Error - Invalid bank
SYM  F46E  << Error - Invalid bank
SYM  F470  << Error - Invalid bank
SYM  F472  << Error - Invalid bank
SYM  F474  << Error - Invalid bank
SYM  F476  << Error - Invalid bank
SYM  F478  << Error - Invalid bank
SYM  F47A  << Error - Invalid bank
SYM  F47C  << Error - Invalid bank
SYM  F47E  << Error - Invalid bank
SYM  F480  << Error - Invalid bank
SYM  F482  << Error - Invalid bank
SYM  F484  << Error - Invalid bank
SYM  F486  << Error - Invalid bank
SYM  F488  << Error - Invalid bank
SYM  F48A  << Error - Invalid bank
SYM  F48C  << Error - Invalid bank
SYM  F48E  << Error - Invalid bank
SYM  F490  << Error - Invalid bank
SYM  F492  << Error - Invalid bank
SYM  F494  << Error - Invalid bank
SYM  F496  << Error - Invalid bank
SYM  F498  << Error - Invalid bank
SYM  F49A  << Error - Invalid bank
SYM  F49C  << Error - Invalid bank
SYM  F49E  << Error - Invalid bank
SYM  F4A0  << Error - Invalid bank
SYM  F4A2  << Error - Invalid bank
SYM  F4C2  << Error - Invalid bank
SYM  F4C3  << Error - Invalid bank
SYM  F4C4  << Error - Invalid bank
SYM  F4C5  << Error - Invalid bank
SYM  F4C6  << Error - Invalid bank
SYM  F4C7  << Error - Invalid bank
SYM  F4C8  << Error - Invalid bank
SYM  F4C9  << Error - Invalid bank
SYM  F4CA  << Error - Invalid bank
SYM  F4CB  << Error - Invalid bank
SYM  F4CC  << Error - Invalid bank
SYM  F4CD  << Error - Invalid bank
SYM  F4CE  << Error - Invalid bank
SYM  F4CF  << Error - Invalid bank
SYM  F4D0  << Error - Invalid bank
SYM  F4D1  << Error - Invalid bank
SYM  F4D2  << Error - Invalid bank
SYM  F4D3  << Error - Invalid bank
SYM  F4D4  << Error - Invalid bank
SYM  F4D5  << Error - Invalid bank
SYM  F4D6  << Error - Invalid bank
SYM  F4D7  << Error - Invalid bank
SYM  F4D8  << Error - Invalid bank
SYM  F4D9  << Error - Invalid bank
SYM  F4DA  << Error - Invalid bank
SYM  F4DB  << Error - Invalid bank
SYM  F4DC  << Error - Invalid bank
SYM  F4DD  << Error - Invalid bank
SYM  F4DE  << Error - Invalid bank
SYM  F4DF  << Error - Invalid bank
SYM  F4E0  << Error - Invalid bank
SYM  F4E1  << Error - Invalid bank
SYM  F4E2  << Error - Invalid bank
SYM  F4E3  << Error - Invalid bank
SYM  F4E4  << Error - Invalid bank
SYM  F4E5  << Error - Invalid bank
SYM  F4E6  << Error - Invalid bank
SYM  F4E7  << Error - Invalid bank
SYM  F4E8  << Error - Invalid bank
SYM  F4E9  << Error - Invalid bank
SYM  F4EA  << Error - Invalid bank
SYM  F4EB  << Error - Invalid bank
SYM  F4EC  << Error - Invalid bank
SYM  F4ED  << Error - Invalid bank
SYM  F4EE  << Error - Invalid bank
SYM  F4F0  << Error - Invalid bank
SYM  F4F2  << Error - Invalid bank
SYM  F4F4  << Error - Invalid bank
SYM  F4F6  << Error - Invalid bank
SYM  F4F8  << Error - Invalid bank
SYM  F4FA  << Error - Invalid bank
SYM  F4FC  << Error - Invalid bank
SYM  F4FE  << Error - Invalid bank
SYM  F500  << Error - Invalid bank
SYM  F502  << Error - Invalid bank
SYM  F504  << Error - Invalid bank
SYM  F506  << Error - Invalid bank
SYM  F508  << Error - Invalid bank
SYM  F50A  << Error - Invalid bank
SYM  F50C  << Error - Invalid bank
SYM  F50E  << Error - Invalid bank
SYM  F510  << Error - Invalid bank
SYM  F512  << Error - Invalid bank
SYM  F514  << Error - Invalid bank
SYM  F516  << Error - Invalid bank
SYM  F518  << Error - Invalid bank
SYM  F51A  << Error - Invalid bank
SYM  F51C  << Error - Invalid bank
SYM  F51E  << Error - Invalid bank
SYM  F520  << Error - Invalid bank
SYM  F522  << Error - Invalid bank
SYM  F524  << Error - Invalid bank
SYM  F526  << Error - Invalid bank
SYM  F528  << Error - Invalid bank
SYM  F52A  << Error - Invalid bank
SYM  F52C  << Error - Invalid bank
SYM  F52E  << Error - Invalid bank
SYM  F530  << Error - Invalid bank
SYM  F532  << Error - Invalid bank
SYM  F534  << Error - Invalid bank
SYM  F538  << Error - Invalid bank
SYM  F53C  << Error - Invalid bank
SYM  F53E  << Error - Invalid bank
SYM  F53F  << Error - Invalid bank
SYM  F540  << Error - Invalid bank
SYM  F541  << Error - Invalid bank
SYM  F542  << Error - Invalid bank
SYM  F543  << Error - Invalid bank
SYM  F544  << Error - Invalid bank
SYM  F546  << Error - Invalid bank
SYM  F548  << Error - Invalid bank
SYM  F54A  << Error - Invalid bank
SYM  F54C  << Error - Invalid bank
SYM  F54E  << Error - Invalid bank
SYM  F550  << Error - Invalid bank
SYM  F552  << Error - Invalid bank
SYM  F553  << Error - Invalid bank
SYM  F554  << Error - Invalid bank
SYM  F555  << Error - Invalid bank
SYM  2280  << Error - Invalid bank
SYM  44C0  << Error - Invalid bank
WOR 2004 2009 << Error - Invalid bank
You're still using the 16B dir.
Here's the dir updated for SAD4.12.
RZASAMY_DIR_4-12.zip
(58.02 KiB) Downloaded 557 times
V5.02 does not like the symbol address stacking generated from the DMR file... give it time.
Thanks. I'll give it a try. I figured I would just try and be a little helpful and report what I was getting with V5. I know it is a development version. I can be patient.
Add these to your DIR
SYM  120E "LOOP_TIME"                     #UW #
SYM  1210 "LOOP_TIME_EXT"                 #UY #
SYM 17554                                 #UY # Timer Command Structure
These can be added to your CMT
086C8 # [120E]
086CD # [1210]
086D7 # [1070]
086E9 # [120E]
086ED # [1210]
086F1 # [1212]
086FB # [1212]
08701 # [1213]
0870E # [1213]
08714 # [172A]
08719 # [1729]
