Electric fan control on Sd4x
Re: Electric fan control on Sd4x
Low Speed Output 1 and 3 are available, on/off.
sym 46 "AM1" : B 0
sym 46 "B1_??_R46" : B1 // No connection
sym 46 "EVR" : B2
sym 46 "B3_??_R46" : B3  // No connection
sym 46 "FLG_SS_1" : B4
sym 46 "FLG_SS_2" : B5
sym 46 "WOT_AC" : B 6
sym 46 "PUMP" : B 7
Amazing! Thank you. Do you know how to safely connect those CPU pins to the main connector to limit risk of damaging the CPU? Are some basic components needed or just wire it up?
The LSO pins are standard TTL, so 3.3v-5V and probably 50mA.
There are multiple routes to go. Only direct connect to another TTL device.
You will need to make a small circuit with a resistor, a diode, and transistor as an input from the CPU LSO.
Then your external relay is switched on from the transistor. The transistor is switched on from the LSO.
You are going to need to know how many Amps the electric fan draws. Say it is on a 20Amp fuse. You could then get a 5v TTL coil driven high current relay that supports 12v/25Amps. Then you won't need extra components, just drive the relay directly if it is TTL. These exist in the Arduino world.
I think the easiest, is to wire the CPU pin from the board, to the spare 60pin pin on the circuit board, just a straight wire, then that is done, and less chance of screwing something else up on the board. Of course you could use say pin #34 on the 60-pin connector, follow its trace, you will notice it goes to a blank missing component with 14? or 16? pins. This is for Data Output Link(DOL or TripMinder), and the chip drives PWM to the TripMinder from the CPU.
What I am saying, is you could run a smaller wire from LSO CPU pin, that missing chip area, then solder in components to drive Pin#34. Then your 60pin under the hood is a 5V on/off ready to go.
I am planning on using DOL, pin#34 as I have a TripMinder from a 92ish TBird that I'm putting in my dash.
Next wire up the pin on the 60pin connector to your relay, or your custom TTL relay driver.
This is just off the top of my head.
I will be doing similar soon, I have a VGT that I am planning on hooking up, but using HSO.
Thanks for these details. I was under the impression that setting a pin to high connects it to ground. Can I just use the 5v ref pin to drive the 5v relay and control the ground with the LSO pin?
absolutely not
transistors revolutionized integrated circuits for that very purpose
Noted thanks lol
I think this is a good option. The fans are only 90 watts each, so I could use this board and control them independently with the two different outputs. You see any issues with that?
https://www.sainsmart.com/collections/r ... lay-module
You could but I personally wouldn't.
You want TWO 20amp MINIMUM relays wired in parallel for a fan. You should never use a single relay for a fan.
You shouldn't have to bother with any of that though. Surely you have a digital output your not using that you can assign to fan duty.
I'm pretty sure I exhausted all the possibilities. The 4x4 is using what normally would be extra outputs.
I could wire these up in parallel.
https://www.sainsmart.com/products/4-ch ... lay-module
What about the ac wot cut output? Your still using the thermactor smog pump? You could even use the mil output if you wanted.
why would you want to use something like that? Seems like an aweful lot extra to shove inside the ecu case. Ideally you want the relays outside the ecu that way your not running a power feed wire inside the ecu.
In Cali I have to leave the mil and smog pump alone. The ac cut makes sense. I'll see about using 12v relays and putting it in the engine compartment instead of in the ECU case.
