I'm not too familiar with data logging in tuner pro but have been playing with it the last couple days a little at a time. Under flags it is showing injector 1 and injector 8 in red letters like it's flagging it for a fault. koeo flag is in red as well. I have also noticed the ect jumping up and down from a low negative value up to over 100 very quickly.I have had an engine surge at idle since I started running this strategy. The temp value jumping around could very well explain this surge.
Looking at obd data coolant temp is reading correctly and gauge on the instrument cluster is accurate as well, not jumping around. I started setting up mechanical idle but stopped due to the surging and my other findings.
This must be what you meant when you said I was in failure management.
cvaf1 strategy questions
mechanicalmatch
CVAF1
4R70 3.08
Re: cvaf1 strategy questions
Make sure you have datalogging enabled in your tune.
mechanicalmatch
CVAF1
4R70 3.08
Yes sir. I noticed that this morning. I guess I had disabled it at one point. I renabled this morning. The only flags that show red now was knock sensor 1. Still getting wacked out readings on everything else. Gonna go back and read the the write ups again pertaining to datalogs.
may be a mislinked adx to xdf patch code
mechanicalmatch
CVAF1
4R70 3.08
Would you please elaborate on that statement? Not sure what you are referring to.
The xdf patch code has to match the adx your using with it. If one is a newer update than the other then it won't poll correctly.
Did you enable the dma datalogging patch code in your tune before writing?
mechanicalmatch
CVAF1
4R70 3.08
I applied disable patch the enabled dma datalog patch with koeo. I am using the latest files you posted up, CVAF1_201005xdf.xdf and DECIPHA_212019.adx.
I just redownloaded and retried the patch to be sure I didnt have a file issue. No change.
