New Tune and recommendations on supporting mods
m-barans
Re: New Tune and recommendations on supporting mods
Wow! Thanks for the information!
m-barans
Decipha, what do you recommend for a replacement PPRV? How/where can I get one?
A few questions:
How does a properly functioning PPRV function? My current understanding is that it is a valve that dumps pressure when it gets too high. Like a pressure relief valve in a hydraulic circuit would. A spring loaded bypass if you will.
Does a pprv function better than an external regulator near the tank and why?
Not trying to complicate anything just trying to be solution oriented and also gain some knowledge and understanding as well.
I’m on board with redoing a replacement pprv if I can source one and I would like to know more about how it benefits the tune.
Am I losing something by reducing pump prime time?
Please share
Apologies if my questioning is unclear
A few questions:
Please share
pprv is a regulator, functions 100% identical
nope, pump prime time is good stuff thats why i created it
if you have a regulator then you have a pprv either will do the same job no prob
