Questions understanding reading logs
MX-Brad
Vehicle Information: 1990 5.0 swapped Miata T5 7.5irs w/3.27
Re: Questions understanding reading logs
Unread post by MX-Brad »
Quick question. Is there a way to log TPS voltage?
I found the gauge under "values" but it doesn't appear to be mapped for logging.
I'm having a part throttle hang that I'm trying to diagnose.
its on the dash already at the upper left. TPREL is what you want to look at.
MX-Brad
TP_REL_CALC ?
How do I convert that to volts?
No conversion needed
as long as it reads 0 at closed throttle its perfect
Hey Brad, i mentioned this over on the corral. I think your best bet is to check voltage at the TPS when its having the issue and compare it to whatever it is when cold/ not having the issue. That is the easiest way to verify if it is the tps or not.
MX-Brad
Ok thanks, and will do.
