bank 1 rich bank 2 ok
Re: bank 1 rich bank 2 ok
repin is just 3 wires see the homepage
yeah cbaza ill post it
lugbolt
Vehicle Information: 1992 ford mustang gt A9P 10.5:1 pump gas 408"w AFR205 T56 Magnum 8.8/3.73
Unread post by lugbolt »
Next question.
Repin done, but I still have to button things up.
I remember from years back, if you used an A9L with an automatic car, you'd typically burn the computer's PCB up.
Using this CBAZA puter, is that an issue or no?
dont think so but you have an auto ecu regardless so doesnt matter
034v
Unread post by 034v »
lugbolt wrote: ↑2021 Oct 17, 19:10 Next question.
Not 100% but I thought that had to do with the reversal of the O2 wiring or something. A9L vs A9P or A3M or something. It's been years since I've even seen a A9P so I could be wrong.
Danno5.0
Vehicle Information: 1995 Ford Mustang GT
W4HO
Professional Products EFI Intake
Crane 2031 cam
Ported E7 heads
Mac shorties, xpipe, mufflers
3000 stall, Transgo, 3.73
Tweecer R/T, LC1 wb
Unread post by Danno5.0 »
Any chance you checked your intake gaskets? I've see a thread someone was having the same issue and it ended up being a set of 1250 felpros getting squished out. Just an idea?
lugbolt
yeah I checked them. Smoke tested the intake. Smoke tested the crankcase with the elbow/throttle body off looking for smoke up through the intake runners. Checks out fine.
probably a bad injector
lugbolt
pulled injectors, sent them out, they all flow the same, no leakage--everything came back perfect as I expected them to. I'd have thought that if I swapped them side to side, if one was bad, the problem would follow and it did not. Still lost on this deal.
At a car show the other day I had mentioned to someone there about this problem and he asked if I had an aluminum flywheel. I do. Guy said he had to swap his back to steel and it made a difference. I can't understand why though. Weird!
Yeah i would call bs on that.
Apex
1996 Ford Mustang
2007 Ford F-150 5.4 3v
Unread post by Apex »
Have you tried just running it in open loop? Or can you just temporarily run both banks off of the bank 2 HEGO and read the plugs?
I suspect that maybe your exhaust leaks you mentioned are introducing air to the o2 sensor, causing false lean readings when the spark plugs are showing rich. I don't think reading plugs is a very definitive test, but if they are showing black and sooty despite "running lean" I would trust the plugs over the o2 sensor reading (unless you are misfiring of course, in which case the sensors will run lean as raw fuel is not read by them).
One thing you can try to fix the flange leak is using the high temp gasket maker (red or orange typically) to seal up the header flanges. From what I've been told this isn't extremely uncommon to have to do with long tube headers, I assume the proper fix would be to have the flanges decked or otherwise made to be flat.
