Page 2 of 3
Re: E4OD Calibration Constants
Posted: 2023 Nov 18, 00:42
by efloth
wow man do you mind sharing your xdf. I think adapting kid2 may be easier then adding all of this to a1c
Posted: 2023 Nov 18, 12:07
by wwhite
My xdf is minimal, not complete, the dir/cmt(disassembly) is near 100%.
Been playing with the gui version of sad, it can create the xdf from the dir, but not complete either.
No easy way to get complete working xdf.
Posted: 2023 Nov 18, 14:08
by jsa
Tunerpro has an import from csv menu item for xdf, anyone tried that to import into xdf?
Posted: 2023 Nov 21, 12:40
by efloth
I play around with that. I didn't find the kid2 bin anywhere. Please post it and I will work on this.
Posted: 2023 Nov 21, 14:21
i never knew about this option. I will have to dig in to it as it could save me a bunch of time making numerous strategies all consistent.
Posted: 2023 Nov 21, 14:35
by efloth
For the sd strats I did a simple find/replace with two columns of addresses on the decrypted xdf. Work would need to be done to add the missing items but the computer does the rest.
Posted: 2023 Nov 21, 23:24
by wwhite
efloth wrote: ↑2023 Nov 21, 12:40
Enjoy, all included: .bin, .dir, .cmt, .msg, .lst.
Only a handful of subroutines I have not found.
- KID2_all.zip
- KID2 .bin .cmt .dir .lst .msg
- (358.39 KiB) Downloaded 847 times
Posted: 2024 Jan 01, 09:47
by efloth
This imports into tunerpro correctly It has all 972 calibration constants from lhbh1. Types, address and other data needs to be added. I completed the first item and It does dump into tunerpro. Must first be saved as a tab delimitted txt file. Some Info from the tunerpro manual:
ObjType Integer
0 for Field ID Header
5 for Scalar
6 for Flag
7 for Table
8 for Function
Posted: 2024 Jan 03, 10:48
by wwhite
Anyone used the SAD806x windows gui?
The developer goes by the name 'thepym'.
Windows executable here:
https://github.com/OpenEEC-Project/SAD8 ... master/Exe
It has built in database to save info like what is in the above spreadsheet.
And has built in create XDF file for TunerPro.
I had it working a couple years ago, wasn't perfect.
I'm wondering if using this tool is better for managing multiple bins.
Posted: 2024 Jan 03, 18:38
by jsa
I have used it but it will not but it will not disassemble some bins.
