A/C On - Surging Idle - Low AFRs
Schemasservice
- Vehicle Information: 68 Mustang with 96 Explorer 5.0H.O. Stroked to 347. Trickflow intake/ heads. Flowtech custom Cam. CTBAE, SLL4.
Re: A/C On - Surging Idle - Low AFRs
Check voltage drop from compressor to battery ground with compressor running. It should be close to 0. check your grounds. compressor to engine block, engine block to frame. A bad ground can cause this with voltage backfeeding where ever it can.
