[solved] convert 224K to 256K
therocks
Vehicle Information: x3 1997/2000 PUMA 1.7 MUFF / TAPE / DUDE
1997 PUMA 1.4 PEST
2001 PUMA 1.6 CHCA
MONDEO MK3 ST220 6BDB
MONDEO MK3 DURATEC25 1RRC
Re: convert 224K to 256K
Unread post by therocks »
I don't delete 65536, i don't put it
look at this
test focus mk1 256KO.bin
(256 KiB) Downloaded 913 times
therocks
1997 PUMA 1.4 PEST
2001 PUMA 1.6 CHCA
you can confirm me that start adress for the bank in 256k files
bank 0 start adress 0x02000
bank 1 start adress 0x12000
bank 8 start adress 0x22000
bank 9 start adresss 0x32000
and bank order also 0-1-8-9?
thanks
it was originally 1-8-0-9 thats how kess and pcmflash read
swappoed over to 256k 0-1-8-9
FORD FOCUS MK1 origine_256k.bin
(256 KiB) Downloaded 761 times
therocks
1997 PUMA 1.4 PEST
2001 PUMA 1.6 CHCA
thanks i will try i way you
therocks
1997 PUMA 1.4 PEST
2001 PUMA 1.6 CHCA
Is not working, dashboard without display and no communication with diagnostic
I can't be of any help then unless you have a quarterhorse to read the ecu out.
therocks
1997 PUMA 1.4 PEST
2001 PUMA 1.6 CHCA
i will buy it .
quaterhorse read full? and sort file of 256KO?
yep its in the getting started write up
therocks
1997 PUMA 1.4 PEST
2001 PUMA 1.6 CHCA
Hi,
i have receive the QH setup as describe in getting started.
read the pcm by 2 method on car and on table (i have homemade harness for check pcm without car)
here the 2 bin read, they are the same but no bank order (FF FA 27 FE,...)
if you see what cause this.
thanks
ON TABLE TEST PAIL QH.bin
(256 KiB) Downloaded 752 times
on car TEST PAIL QH.bin
(256 KiB) Downloaded 793 times
both reads are the same so thats promising
Doesn't look like any american code I've ever seen.
