2006 Mustang & 1993 MarkVIII engine and transmission
Re: 2006 Mustang & 1993 MarkVIII engine and transmission
No your not using the mustang pcm or harness so you dont have to do anything with it just leave it be.
Pguercio1
Vehicle Information: 2006 Ford Mustang with
4.6l DOHC from 93 Mark VIII
Unread post by Pguercio1 »
Hi Michael,
I’ve got most of the wiring done,
The only ones I’m not sure about where to
plug into on the Lincoln harness are;
Pin 8 fuel pump monitor
Pin 18 data +
Pin 19 data -
Pin 22 enable fuel pump output
The rest I got!
Please if you could help, it would be appreciated
fpm is to check the fp relay works you dont need it
- and + are for the dtc connector, you dont need it
22 is the fp relay ground trigger output. You wire that up to your fuel pump relay ground trgger.
Pguercio1
Ok great
I’ll finish it tomorrow night
One other question and I should be in good shape,
The Mustang instrument cluster how do I hook that up, since I’m not using the Mustang’s ECM ?
You don't the old ecu doesnt support it.
Pguercio1
Ok
So what do I do about the gauges
instrumentation? Any suggestions?
Pguercio1
How can I get the cooling to run properly?
Pguercio1
Michael,
How do I get the cooling fan to run properly?
Pguercio1
Hi Michael,
I’ll hook up the VCRM for the cooling
fans to work properly, the only issue left
is the gauges…any suggestions?
you can get a gps speedo, thats about it otherwise you'd have to swap ecu's or swap in the old lincoln cluster which is analog
