did you click the connect button at the top of tuner pro? You have to tell tuner pro to connect to the Moates. The icon looks like an old printer cable. I think there is a tunerpro write up on here somewhere.
edit: http://www.efidynotuning.com/started.htm Go down to the writing to the quarterhorse section. It shows the button I was talking about. If you havent already read that over, you should.
Tuning laptop recommendation
Re: Tuning laptop recommendation
I have attached the latest driver. You will need extract the zip and manually select the extracted files in the update driver wizard. I believe a second device appears after you install the first one. Follow the wizard a second time and point it to the same folder.
- CDM+v2.12.36.1+WHQL+Certified.zip
- (1.39 MiB) Downloaded 619 times
m-barans
You’re going to have to download the ftdi driver software for whichever machine you choose to use. Also reference the getting started write up to make sure tuner pro RT settings are all correct as outlined.
Yes I will double check settings, and did try the connect button. I've been using tunerpro for years now but the new laptop doesn't like it. My work IT guy erased tunerpro without telling me. With that said I want to use something other than the work tablet.
I'll try the drivers next.
any luck?
