ZYA2 not work?
Red Mach1
- Vehicle Information: 2003 Mach1, stock engine with Comp cams 106100
ZYA2 not work?
Hello. I tried write zYA2 into my mach1. After write complete(pcm flash), fuel pump ticking with ignition on. I tried identicication button in my pcm flash, pcm flash display error on vin and strategy, immo light on, radiator fan activate with ignition on, sym2 same problem but AMZ_stock, MGZT_stock works without problem. I only insert vin and pats code into all bins.I was not tried start car...
Attached picture from amz2 write...on zya2 is ERROR status at strategy and vin location...
Re: ZYA2 not work?
bin has to be 224k for pcmflash to write
you need to tune it with tunerpro and the qh first before you write it
Red Mach1
Re: ZYA2 not work?
256k bin open in tuner pro, insert vin amd pats after closed tuner pro was convrted to 224...with amz2 works
Re: ZYA2 not work?
the code at 1319b is all corrupted
mechanicalmatch
CVAF1
4R70 3.08
Re: ZYA2 not work?
Are you using tool from custom ecm solutions to swap the banks?
Red Mach1
Re: ZYA2 not work?
Yes. Picture attached higher.
Red Mach1
Re: ZYA2 not work?
Wrongly converted to 224?
How I can fix it?
78?
Re: ZYA2 not work?
your missing a ton of code. You have to put the missing code back in.
Red Mach1
Re: ZYA2 not work?
Code lost after converter convert bin to 224? Converter not work properly? I Need used another converter or manual bank swap? Couldnt you convert 256 to 224 right way for my please? I will compare, search differences because now I dont have idea where code missing...why code lost. SORRY for many questions.
Red Mach1
Re: ZYA2 not work?
Couldnt these problems here for reason I not have US regional setting in my pc, binary editor works only if pc set on US regional setting in windows.
