03/04 Mach 1
Re: 03/04 Mach 1
Update, I got the idle fuel pretty much dialed in. The one thing that im seeing is the fuel error on the dash and the fuel error on the histogram are giving two different readings. Im assuming i need to go by the histogram instead of the dash. Also the tune that decipha has come up with for a base is pretty dang good for starting out. My cranking fuel is dead on for cold and hot starts. Hopefully ill get to drive the car tonight or tomorrow and get some good data. Also which base fuel table should i look at for idle, cruise and WOT fuel?
Re: 03/04 Mach 1
I posted stock auto and manual fbgi0 cals last night
Re: 03/04 Mach 1
Sweet!! I really appreciate you and what you do for the diy community.
