Bench Testing MAP Sensor - Boost
Re: Bench Testing MAP Sensor - Boost
For logging you need to stw to a spare ram address, say 0xDf0 through 0xDfe right after the function look up returns. R38 is a scratch reg so it it overwritten by all sorts.
efloth wrote: ↑2022 Sep 28, 19:08 I tried this again today with a0. Same story. Data logging doesn't work when this error is occurring the items on the dash are either not updating or flickering back and forth between two values. I think r38 changing at this point in the code is causing the issue. Maybe I should store the value in r38 and put it back when I'm done? Is there a safe address zone for temporary storage somewhere?
38ff: c3,e4,a2,58 stw R58,[Re4+a2] MAP_FREQ = R58;
3903: ef,03,0e call 4709 UUWFuncLU_4709 (
3906: fe,cd #arg 1 Func_c1ac,
3908: 58,00 #arg 2 58 );
390a: a2,38,56 ldw R56,[R38] R56 = [R38];
390d: ef,f9,0d call 4709 UUWFuncLU_4709 (
3910: fe,ce #arg 1 Func_c2ac,
3912: 58,00 #arg 2 58 );
3914: a2,38,5c ldw R5c,[R38] R5c = [R38];
R38 is the output that is stored in R56 then R5c, no need to store it again.
It is not clear to me that R56 & R5C are unchanged elsewhere in the bin. One needs to understand the whole bin. So I suggested storing the values elsewhere for bug finding purposes.
I also take patchcode issues out of the picture for debug purposes.
R5C = OFSET#(1-6) = Offset for the sixth linear equation describing MAP as a function of frequency and inches of Hg.
R56 = SLOPE#(1-6) = Slope for the first linear equation for MAP.
MAP_FREQ = [(ISF + 6 + lsf) * 0.5] / DT12SA
MAP_WORD = SLOPE(x) * MAP_FREQ - OFSET(x)
I'll be testing this theory today.
MAP_CALC:
3903: a1,f0,0d,f0 ldw Rf0,df0 Rf0 = df0;
3907: c3,f0,00,38 stw R38,[Rf0+0] [Rf0+0] = R38;
390b: ef,fb,0d call 4709 UUWFuncLU_4709 (
390e: fe,cd #arg 1 Func_c1ac,
3910: 58,00 #arg 2 58 );
3912: a0,38,56 ldw R56,R38 R56 = R38;
3915: ef,f1,0d call 4709 UUWFuncLU_4709 (
3918: fe,ce #arg 1 Func_c2ac,
391a: 58,00 #arg 2 58 );
391c: a0,38,56 ldw R56,R38 R56 = R38;
391f: a3,f0,00,38 ldw R38,[Rf0+0] R38 = [Rf0+0];
3923: 20,5e sjmp 3983 goto 3983;
3925 -> 3982 = 0xff ## fill ##
3983: 6c,56,58 ml2w R58,R56 lR58 *= R56;
3986: 68,5c,5a sb2w R5a,R5c R5a -= R5c;
3989: c3,e4,a6,5a stw R5a,[Re4+a6] IMAP_WORD = R5a;
398d: 91,40,a0 orb Ra0,40 B6_MUPET_FLAG_a0 = 1;
3990: 91,01,a1 orb Ra1,1 B0_MAPUP_NORM_a1 = 1;
3993: 38,a7,19 jb B0,Ra7,39af if (B0_V_VACFLG_a7 = 0) {
3996: 71,f7,a6 an2b Ra6,f7 B3_MFMFLG_a6 = 0;
3999: c3,e4,a4,5a stw R5a,[Re4+a4] MAP_WORD = R5a;
399d: 09,03,5a shlw R5a,3 R5a <<= 3;
39a0: b0,5b,ba ldb Rba,R5b MAP = R5b;
39a3: 91,20,52 orb R52,20 B5_ISF_UP_FLG_52 = 1;
39a6: c3,e4,a0,00 stw R0,[Re4+a0] DT12SA = 0;
39aa: c3,e4,a8,00 stw R0,[Re4+a8] MAPCNT = 0;
39ae: f0 ret return; }
39af: 91,08,a6 orb Ra6,8 B3_MFMFLG_a6 = 1;
39b2: 27,ef sjmp 39a3 goto 39a3;
Your code snippet is, um, not correct. R56 is written twice first value set by Func_c1ac is overwritten when Func_c2ac sets R56 again.
R5C is not set.
Not sure if you realize the code changes you have made do not look correct to me.
Nice catch! Thanks for proof reading my code The second function should be written to R5c as before.
Rf0 is typically an Rbase, so you don't want to overwrite it.
You can STW to [R0+DF0]
Rf0 = df0
c3,01,F0,0D,38
This code works beautifully on the bench using compressed air. Map_word appears to be correct but I'm not sure how mapope is calculated. Anyone have a turbo setup to try this on?
MAP_CALC:
c200: 89,6c,59,58 cmpw R58,596c
c204: db,0e jc c214 if (R58 < 596c) {
c206: a1,6c,59,58 ldw R58,596c R58 = 596c;
c20a: a1,bd,6c,56 ldw R56,6cbd R56 = 6cbd;
c20e: a1,21,23,5c ldw R5c,2321 R5c = 2321;
c212: 20,de sjmp c2f2 goto c2f2; }
c214: 89,5f,64,58 cmpw R58,645f
c218: db,0a jc c224 if (R58 < 645f) {
c21a: a1,bd,6e,56 ldw R56,6ebd R56 = 6ebd;
c21e: a1,21,23,5c ldw R5c,2321 R5c = 2321;
c222: 20,ce sjmp c2f2 goto c2f2; }
c224: 89,5a,71,58 cmpw R58,715a
c228: db,0a jc c234 if (R58 < 715a) {
c22a: a1,f1,69,56 ldw R56,69f1 R56 = 69f1;
c22e: a1,4a,21,5c ldw R5c,214a R5c = 214a;
c232: 20,be sjmp c2f2 goto c2f2; }
c234: 89,db,7c,58 cmpw R58,7cdb
c238: db,0a jc c244 if (R58 < 7cdb) {
c23a: a1,88,63,56 ldw R56,6388 R56 = 6388;
c23e: a1,7b,1e,5c ldw R5c,1e7b R5c = 1e7b;
c242: 20,ae sjmp c2f2 goto c2f2; }
c244: 89,e0,88,58 cmpw R58,88e0
c248: db,0a jc c254 if (R58 < 88e0) {
c24a: a1,c4,5e,56 ldw R56,5ec4 R56 = 5ec4;
c24e: a1,2a,1c,5c ldw R5c,1c2a R5c = 1c2a;
c252: 20,9e sjmp c2f2 goto c2f2; }
c254: 89,72,96,58 cmpw R58,9672
c258: db,0a jc c264 if (R58 < 9672) {
c25a: a1,10,59,56 ldw R56,5910 R56 = 5910;
c25e: a1,19,19,5c ldw R5c,1919 R5c = 1919;
c262: 20,8e sjmp c2f2 goto c2f2; }
c264: 89,3f,a2,58 cmpw R58,a23f
c268: db,0a jc c274 if (R58 < a23f) {
c26a: a1,7e,53,56 ldw R56,537e R56 = 537e;
c26e: a1,d3,15,5c ldw R5c,15d3 R5c = 15d3;
c272: 20,7e sjmp c2f2 goto c2f2; }
c274: 89,ff,ad,58 cmpw R58,adff
c278: db,0a jc c284 if (R58 < adff) {
c27a: a1,00,4e,56 ldw R56,4e00 R56 = 4e00;
c27e: a1,00,13,5c ldw R5c,1300 R5c = 1300;
c282: 20,6e sjmp c2f2 goto c2f2; }
c284: 89,ff,b9,58 cmpw R58,b9ff
c288: db,0a jc c294 if (R58 < b9ff) {
c28a: a1,00,49,56 ldw R56,4900 R56 = 4900;
c28e: a1,00,11,5c ldw R5c,1100 R5c = 1100;
c292: 20,5e sjmp c2f2 goto c2f2; }
c294: 89,ff,c5,58 cmpw R58,c5ff
c298: db,0a jc c2a4 if (R58 < c5ff) {
c29a: a1,00,44,56 ldw R56,4400 R56 = 4400;
c29e: a1,00,0e,5c ldw R5c,e00 R5c = e00;
c2a2: 20,4e sjmp c2f2 goto c2f2; }
c2a4: 89,ff,d1,58 cmpw R58,d1ff
c2a8: db,0a jc c2b4 if (R58 < d1ff) {
c2aa: a1,00,3f,56 ldw R56,3f00 R56 = 3f00;
c2ae: a1,00,0c,5c ldw R5c,c00 R5c = c00;
c2b2: 20,3e sjmp c2f2 goto c2f2; }
c2b4: 89,ff,dd,58 cmpw R58,ddff
c2b8: db,0a jc c2c4 if (R58 < ddff) {
c2ba: a1,00,3a,56 ldw R56,3a00 R56 = 3a00;
c2be: a1,00,0a,5c ldw R5c,a00 R5c = a00;
c2c2: 20,2e sjmp c2f2 goto c2f2; }
c2c4: 89,ff,e9,58 cmpw R58,e9ff
c2c8: db,0a jc c2d4 if (R58 < e9ff) {
c2ca: a1,00,35,56 ldw R56,3500 R56 = 3500;
c2ce: a1,00,07,5c ldw R5c,700 R5c = 700;
c2d2: 20,2e sjmp c302 goto c302; }
c2d4: 89,ff,f5,58 cmpw R58,f5ff
c2d8: db,0a jc c2e4 if (R58 < f5ff) {
c2da: a1,00,30,56 ldw R56,3000 R56 = 3000;
c2de: a1,00,05,5c ldw R5c,500 R5c = 500;
c2e2: 20,0e sjmp c2f2 goto c2f2; }
c2e4: a1,ff,ff,58 ldw R58,ffff R58 = ffff;
c2e8: db,0a jc c2f4 if (R58 < f5ff) {
c2ea: a1,00,2a,56 ldw R56,2a00 R56 = 2a00;
c2ee: a1,00,02,5c ldw R5c,200 R5c = 200;
c2f2: 6c,56,58 ml2w R58,R56 lR58 *= R56;
c2f5: 68,5c,5a sb2w R5a,R5c R5a -= R5c;
c2f8: c3,e4,a6,5a stw R5a,[Re4+a6] IMAP_WORD = R5a;
c2fc: 91,40,a0 orb Ra0,40 B6_MUPET_FLAG_a0 = 1;
c2ff: 91,01,a1 orb Ra1,1 B0_MAPUP_NORM_a1 = 1;
c302: 38,a7,19 jb B0,Ra7,c31e if (B0_V_VACFLG_a7 = 0) {
c305: 71,f7,a6 an2b Ra6,f7 B3_MFMFLG_a6 = 0;
c308: c3,e4,a4,5a stw R5a,[Re4+a4] MAP_WORD = R5a;
c30c: 09,03,5a shlw R5a,3 R5a <<= 3;
c30f: b0,5b,ba ldb Rba,R5b MAP = R5b;
c312: 91,20,52 orb R52,20 B5_ISF_UP_FLG_52 = 1;
c315: c3,e4,a0,00 stw R0,[Re4+a0] DT12SA = 0;
c319: c3,e4,a8,00 stw R0,[Re4+a8] MAPCNT = 0;
c31d: f0 ret return; }
c31e -> ffff = 0xff ## fill ##
