03/04 Mach 1
Re: 03/04 Mach 1
Thanks!
Re: 03/04 Mach 1
Nope and I won't get any free time to get to it anytime soon most likely.
Re: 03/04 Mach 1
I just finished my startup tune for the mach. The car has a 3650 trans, stock 3.55 gears, longtubes and a X-pipe so i applied the patch for only 1 hego and i applied the patch to disable the rear hegos. I turned off the EGR and disabled the PATS as well. Do you mind looking over it when you get a chance? I want to make sure im not missing anything. Thanks again for your support!
- 03Mach_Startup_Tune.bin
- (256 KiB) Downloaded 500 times
Re: 03/04 Mach 1
Heres a revised tune. The one i posted yesterday did not have have DeltaP data updated.
Re: 03/04 Mach 1
what injectors do you have?
read out and post back your stock tune to copy pats over
Re: 03/04 Mach 1
Im using the stock 24s. When i get to that point i will read out the stock tune and post back.
Re: 03/04 Mach 1
The data for the injectors i got off of the homepage and deltaP info from factory ford data sheet.
Re: 03/04 Mach 1
I finally got the mach together and im planning on starting the tuning process tomorrow. Is FN2200 the base spark table? if so is the easiest way to convert it to a N/A 4valve is add 11 degrees to the whole table?
