EL falcon 6 cyl eec running 5.0 v8
Re: EL falcon 6 cyl eec running 5.0 v8
thats cuz theres a newer patch in the tune than in the xdf
it should have logged perfectly all you had to do is click the button
- Vehicle Information: 1995 ford falcon ute 5.0 windsor efi
ok i will load it again.
thank you
thank you
just confirming that the A!C is 8061 processor ??
the HWAD3 (auto) and HWMC2 (manual) are 8065 processors.
i am slowly sorting out the tune and will post it soon .
these are the TI Performance base files.
i dont think i changed them.
6dbd.bin goes with HWAD3
think i worked out how to attach as my computer skills are just above clicking a mouse hahaha.
# Disassembly listing of binary 'A1C' 8061 1 bank SAD Version 4.0.7.16b (11 Apr 2022)
# See 'A1C_msg.txt' for warnings, results and other information
yes a1c is eec-iv 8061 ecu from 80s to 90s
yeah it shouldn't even execute
The 8065 uP will run 8061 software no problem, backwards compatible correct?
I'm going to go a different route with this.
The 6dbd.bin, is speed density and runs on 8065 correct?
My 351w is speed density, so...I'll take my EEC-V 104 pin and run the 6dbd single bank software on it.
Be intersting if it works, then the repinning, etc. etc.
No, for starters the 8061 stack SFR address is different to 8065.
