PCM troubleshooting
Re: PCM troubleshooting
Dang
Mainly because this build has spiralled out of control.
I just need it to run with minimal work at this point. Juggling too many irons in the fire at this point
Even worth plugging the f150 pcm in?
Didnt realize it, but they have a 98 grand marquis as well. Guess ill go swap PCMs tomorrow.
try it worse case it doesnt work
Ay!
Always go back tomorrow.
Well
FOU1 ran with fha3
But it was extremely unhappy and ignored a lot of inputs from the tune with the low speed fan running 24/7
Also to note, random speedo and exterior light fluctuations
Good news is it ran as good as it ever has.
Tomorrow i go back to the yard to try and get a 98 marquis PCM
FOU1 ran with fha3
that means it has a different bidi port mapping so its not interchangeable
The 98 marquis will work right?
you can plug the hardware code on the homepage under supported ecus and it'll tell you
Ok, its supported.
What bin should i run this under?
Its a vtc5 out of a 98 marquis
why not use the same bin youve been using?
I thought your purpose is replacing it with the same ecu was so it was plug and play?
Idk if it needed the auto v8 bin or what
Shit, plugging it in and sending with fha3
