A9L/A9P Rebuild Service?
Chickenbone
Vehicle Information: 1986 Ford Crown Victoria Ltd LX 5.8/AOD no longer stock
Unread post by Chickenbone »
Does anybody out there repair/rebuild these ECMs? I tried Foxresto.com, but they are not responding to phone calls and e-mails. I have an A9P with at least 1 visibly bad capacitor. This has been delaying my 1st start attempts for a while now. Any help would be greatly appreciated.
Re: A9L/A9P Rebuild Service?
you could try an electronics/ computer shop. I think there are only 2 or 3 caps that are known to go bad. You could just have them solder in some new ones.
I replace caps but i don't have a way of testing your computer since i don't have a fox body any more. It would be no different than if you took it to an electronics shop since they won't have a way of testing it either.
Chickenbone
Cool. Thanks for the advice :)
I got through to Foxresto.com and they told me to take my Quarterhorse out and ship the A9P to them. So I will be doing that tonight. Hopefully the damage is repairable.
I set up a bench test, connected power & grounds, ignition, fuel pump to a relay, then connected the self-test wires and a light to the MIL.
Basically made something like this:
https://youtu.be/d5n_wKmueKM
wwhite wrote: ↑2022 Jun 09, 14:08 I set up a bench test, connected power & grounds, ignition, fuel pump to a relay, then connected the self-test wires and a light to the MIL.
That's a good idea.
smangy
Vehicle Information: FFR Shelby daytona coupe
347 sbf tko600
Unread post by smangy »
Where u located
